13.8 v with the engine running is what I see with a dvom on a 5 year old battery.
I had the battery load tested and it is 200cca down. 25% less than a new one.
13.3 is ok within the time span you allowed.
It sounds like the alternator is good, and the battery is good.
It still looks to me that something is causing a battery drain.
Another thing to look into:
With the car running, trunk lid up, squeeze and tug gently on the short span of insulated harness that runs down into the body from the trunk lid.
look for odd electrical behavior from lights, window mechanism, instrument cluster, while you faff with the harness.
Repeat with the engine off.
I've seen starting issues,failure of power window, odd behavior from the instument cluster, on the E30,E36, and Mercedes models, that were traced to a short in the harness from the trunk lid. The short is caused by the fatigue of the wiring at the hinge.
