Well, I just picked up my car after replacing the con rod bearing shells and all power steering components. My mechanic, who I have used for years and trust implicitly, told me my chains (timing chain and oil pump chain) need to be replaced. I can't hear it in the car yet, but he said he could hear it rattling when the car was cold and he turned the steering rack completely in either direction. There is no scoring of aluminium that he could see. What surprised me was that he said he couldn't remember exactly, but thought it was between 20-30 hours. He is always fair, only charged me 9 hours labour to do the connecting rods and whole power steering refresh. I had been planning on a complete cooling refresh this fall and i suppose it would make sense to do it at the same time. But the 20-30 hours seemed high. Perhaps because he said he usually ends up doing the VANOS at the same time. Anyone have thoughts?
Chain Replacements
Tangentially, has anyone directly compared timing chain lengths with new and high mileage s54s?
I'm not sure if I buy the lifetime chain story, other models have had stretch over the miles.2003.5 MT JB/B - CSL SCHRICK SUPERSPRINT EISENMANN JRZ SWIFT MILLWAY APR ENDLESS BBS/SSR DREXLER KMP SACHS RECARO AR SLON MKRS GSP DMG KARBONIUS CP AUTOSOLUTIONS KOYO
How many miles?
I've been in this S54 world for 12 years, and I can't really remember anyone having issues with chain stretch.
I just did a valve adjust on my 123k car, and for fun, pulled on the chain and I couldn't get even lift them off the sprocket at all. They also seem more robust than motorcycle chains that I'm used to.
For perspective, in motocross, you pull the chain off the back of the big (rear) sprocket and if you see light coming through(teeth to chain), you replace.
So did your mechanic pull the chain off the sprocket or measure the length of stretch?
If he's just going off of noise, there could be other culprits, other moving parts in the valvetrain that he may have heard (broken chain guide?)DD: /// 2011.5 Jerez/bamboo E90 M3 · DCT · Slicktop · Instagram
Hot take: sounds line a competent mechanic but possibly not proficient with the s54 specifically. Cant speak for your case specifically but the chains themselves arent known to fail on these motors- but plenty of parts that the chain interact with do.2002 TiAg M3 Coupe (SMG to 6spd), 2003 Jet Black M5
I'm at 215k km (132k miles). He said that he was just going off the noise at this point, which he said was faint. I specifically asked about the chain guide but he would have to get into it to determine. Like I said I plan on doing a complete cooling refresh, and VANOS later this year. So that would be the time to do it all. I was just curious about his off the cuff hours estimate.Originally posted by Tbonem3 View PostHow many miles?
He is quite knowledgable on the s54. He owns an M3, and there is usually at least one other in the lot when I take my car in. He said chain stretch is not common, but he has seen it, usually over 250k km (150k miles).
I don't think motorcycles use a chain tensioner, which takes most of the chain slash out in our car.Originally posted by Tbonem3 View PostFor perspective, in motocross, you pull the chain off the back of the big (rear) sprocket and if you see light coming through(teeth to chain), you replace.
This chain has no open-link, so to loop it around the crank sprocket, the timing cover might need to be removed. Then the vanos has to be re-timed again. The timing cover removal takes a long time.Originally posted by Andrew 06M3Cab View PostI was just curious about his off the cuff hours estimate.
If the tensioner has not bottomed out of range, then I would leave the chain alone.
I had to rebuild my engine around 160k miles or so and have little to no chain stretch compared to a brand new chain. It was so little that it could have been a testing error. Wish I had a picture but unfortunately I didn’t take one.Originally posted by jet_dogg View PostTangentially, has anyone directly compared timing chain lengths with new and high mileage s54s?
How did you compare the two, suspend them or lay on top of each other on a flat surface? A proper method would be a gauge of sorts I imagine.Originally posted by Darbshaw View Post
I'm thinking they're cheap enough to do while I'm in there might as well.2003.5 MT JB/B - CSL SCHRICK SUPERSPRINT EISENMANN JRZ SWIFT MILLWAY APR ENDLESS BBS/SSR DREXLER KMP SACHS RECARO AR SLON MKRS GSP DMG KARBONIUS CP AUTOSOLUTIONS KOYO
One must pull the head to replace the chain on an S54 correct?
I thought I had read online about a shop that had come up with some method of replacing the timing chain without pulling the head and thus saving many hours of labor, maybe I'll come up with the link.2004 Silbergrau Metallic 6MT
To remove the lower timing chain cover you are supposed to pull the head.'09 HP2S, '12 R12GSA, '00 Black 323iT, '02 Alpine 325iT (Track Wagon), '02 Alpine 330iT
Email to [email protected]
