Active INPA error memory list?
    Is there an active INPA error memory code list v.English? I always have trouble finding more info on any faults in the recent history.
    I am currently trying to look for more info on the following error memory fault attached.
    This website lists the error codes by DME, scroll down and you see this:
    • "214 Lambda Sensor Pre Cat Bank 1 Period Duration"
      I also use this list from Martyn very often
      Courtesy of NikolaiD... The first two colums are the error code # in decimal and hexadecimal. The third column tells you if that code will trigger an OBD2 relevant code. The fourth column is the description, some of these have been paraphrased. The last 4 columns are the possible variations of the codes. The variation code
        Thank you both!
