E46 M3 DME / ECU Error Codes
    Courtesy of NikolaiD...
    The first two colums are the error code # in decimal and hexadecimal. The third column tells you if that code will trigger an OBD2 relevant code. The fourth column is the description, some of these have been paraphrased. The last 4 columns are the possible variations of the codes. The variation code table is in post #3.
    For example:
    Code 170, AA, Minimum flow of secondary air, could have four versions: 23-Bench 1 too small; 24-Bench 2 too small; 25-both Benches too small or 09-1000 - Condition / value implausible / over-temperature
    Decimal Hex OBDII? Description V1 V2 V3 V4
    1 01 Relay fuel pump
    2 02 Idle control valve, closing coil
    3 03 P0201,P0261,P0262 Fuel injector, cyl. 1
    4 04 P0203 Fuel injector, cyl. 3
    5 05 P0202,P0264,P0265 Fuel injector, cyl. 2
    6 06 Time out SMG-CAN
    7 07 P0340 Signal, camshaft sensor, inlet
    8 08 Signal, camshaft sensor, outlet
    9 09 YES Signal, knock sensor, cyl. 1-2 06 16 08 09
    10 0A P0365 Signal, camshaft sensor, exhaust
    11 0B Signal, camshaft sensor, intake
    12 0C Signal, oxygen sensor before cat., cyl. 4-6
    13 0D Signal, oxygen sensor before cat., cyl. 1-3
    14 0E DM-TL Heater
    15 0F Camshaft sensor 1, synchronization to crankshaft
    16 10 P0335 Signal, crankshaft sensor
    17 11 SMG shift sequence
    18 12 YES ??? VANOS pressure-accumulator valve 06 07 08 09
    19 13 P0418 Secondary air pump relay
    20 14 Starter relay
    21 15 Exhaust VANOS, retard valve
    22 16 Exhaust VANOS, advance valve
    23 17 YES Ignition coil, cyl. 2 14 15 08 09
    24 18 YES Ignition coil, cyl. 3 14 15 08 09
    25 19 YES Ignition coil, cyl. 1 14 15 08 09
    26 1A YES Ignition coil, cyl. 8 14 15 08 09
    27 1B Tank leakage diagnosis valve
    28 1C YES ??? Function, map cooling E1 E0 08 09
    29 1D Idle control valve opening coil
    30 1E Monitoring AD-converter
    31 1F P0205 Fuel injector, cyl. 5
    32 20 P0206 Fuel injector, cyl. 6
    33 21 P0204 Fuel injector, cyl. 4
    34 22 Fuel injector, cyl. 7
    35 23 Fuel injector, cyl. 8
    36 24 Tank ventilation valve
    37 25 P0135 Oxygen sensor heater before cat., cyl. 1-3 06 07 08 EF
    38 26 P0155 Oxygen sensor heater before cat., cyl. 4-6 06 07 08 EF
    39 27 P0141 Oxygen sensor heater after cat., cyl. 1-3 06 07 08 EF
    40 28 P0161 Oxygen sensor heater after cat., cyl. 4-6 06 07 08 EF
    41 29 Signal, mass air flow sensor
    42 2A P0500 Road speed signal PIN 4-22
    43 2B Signal, temperature sensor, radiator outlet
    44 2C YES Signal, thermal oil level sensor ED EE 08 09
    45 2D Electric throttle: servomotor
    46 2E Output, consumption signal KVA
    47 2F Output, engine-speed signal TD
    48 30 Interface, IHKA relay
    49 31 internal index 95
    50 32 YES Ignition coil, cyl. 4 14 15 08 09
    51 33 YES Ignition coil, cyl. 6 14 15 08 09
    52 34 YES Ignition coil, cyl. 5 14 15 08 09
    53 35 Interface, electric fan relay
    54 36 System voltage, main relay
    55 37 YES Ignition coil, cyl. 7 14 15 08 09
    56 38 internal index 96
    57 39 Signal, mass air flow sensor, left
    58 3A Voltage supply, sensors 1
    59 3B Voltage supply, sensors 2
    60 3C Signal, pedal travel sensor 1
    61 3D Signal, pedal travel sensor 2
    62 3E internal index 97
    63 3F Secondary air valve
    64 40 internal index 98
    65 41 Signal, throttle potentiometer and el. throttle actuator
    66 42 EWS interface: no communication
    67 43 Inlet VANOS, advance valve
    68 44 SMG safety concept
    69 45 YES Signal, knock sensor, cyl. 3-4 06 16 08 09
    70 46 YES Signal, knock sensor, cyl. 5-6 06 16 08 09
    71 47 YES Signal, knock sensor, cyl. 7-8 06 16 08 09
    72 48 Inlet VANOS, retard valve
    73 49 YES Signal, mass air flow sensor, implausible 06 07 08 E5
    74 4A Inlet VANOS, bank 2, advance valve
    75 4B Inlet VANOS, bank 2, retard valve
    76 4C Ambient pressure sensor (DME internal)
    77 4D Intake manifold air temperature sensor
    78 4E YES Signal, temperature sensor, coolant 06 07 08 E4
    79 4F Signal, temperature sensor, exhaust gas
    80 50 YES Switch chain, frictional connection 1D 07 1E 09
    81 51 YES Interface, multifunction steering wheel B4 0E B6 B7
    82 52 Activation, exhaust flap
    83 53 Exhaust VANOS, bank 2, advance valve
    84 54 Exhaust VANOS, bank 2, retard valve
    85 55 Signal, throttle-valve potentiometer
    86 56 P0600 No CAN-bus signal to DME 0D 07 08 09
    87 57 P0140 Signal, oxygen sensor after cat., cyl. 1-3
    88 58 P0160 Signal, oxygen sensor after cat., cyl. 4-6
    89 59 Internal DME fault
    90 5A YES Trim control, cyl. 1-3 DC DD 08 09
    91 5B YES Trim control, cyl. 4-6 DC DD 08 09
    92 5C P0139 Oxygen sensor after cat., cyl. 1-3: voltage monitoring 06 07 DE DF
    93 5D P0159 Oxygen sensor after cat., cyl. 4-6: voltage monitoring 06 07 DE DF
    94 5E Inlet-VANOS adaptation
    95 5F Exhaust-VANOS adaptation
    96 60 YES Radiator outlet temperature implausible 06 07 08 50
    97 61 internal index 244
    98 62 internal index 245
    99 63 Internal DME fault
    100 64 ??? Internal error / Signal, tire pressure, front left
    101 65 Signal, tire pressure, front right
    102 66 Signal, tire pressure, rear right
    103 67 Signal, tire pressure, rear left
    104 68 ??? Wrong values in fault memory
    105 69 Plausibility engine temperature
    106 6A Signal, brake light switch
    107 6B YES Electric throttle: self-test E0 20 21 22
    108 6C Activation, oil circuit changeover valve, left
    109 6D Activation, oil circuit changeover valve, right
    110 6E Function light, switch, driving dynamics
    111 6F YES Pedal travel sensor, comparison fault 06 B5 08 09
    112 70 YES Pedal-position sensor, comparison fault 06 B5 08 09
    113 71 YES Function, inlet VANOS, bank 2 18 19 1A 09
    114 72 YES Function, exhaust VANOS, bank 2 18 19 1A 09
    115 73 internal: ECU-temperature
    Continued in next post.
    116 74 Activation, valve, Servotronic
    117 75 YES Road speed signal via CAN 06 07 E9 09
    118 76 Electric throttle: signal, potentiometer, throttle
    119 77 P0221 Signal, potentiometer, servomotor 06 B5 08 09
    120 78 YES Electric throttle: potentiometer, signal comparison 06 B5 08 09
    121 79 YES Electric throttle: both potentiometers faulty 06 07 FA 09
    122 7A YES DME internal processor check
    123 7B No CAN-bus signal from SMG
    124 7C YES CSL intake flap 06 07 08 09
    125 7D YES Function lamp, oil level 06 07 08 09
    126 7E Crash deactivation, fuel pump
    127 7F YES Tank leakage diagnosis module 06 EB FE FF
    128 80 Deviation idling speed
    129 81 YES Cat. protection function – limp mode 06 07 08 09
    130 82 YES EWS 3.3 tampering protection 10 11 12 13
    131 83 YES DSC intervention implausible 06 07 08 0B
    132 84 P1613 CAN timeout DSC 06 07 0C 09
    133 85 P0600 CAN timeout, steering angle sensor 06 07 0C 09
    134 86 YES CAN timeout, instrument cluster 06 07 0C 09
    135 87 P0500 No road speed signal 08 08 08 08
    136 88 YES Function, idle speed control E0 E1 E2 09
    137 89 Suction-jet pump
    138 8A Activation, differential lock
    139 8B P0564 Interruption, cruise-control operation B0 B1 B2 B3
    140 8C YES Knock control deactivated/knock protection 17 07 F7 09
    141 8D Tank fill level implausible
    142 8E System check, suction jet pump for brake boosting
    143 8F Activation, electronics box fan
    144 90 YES Function, oxygen sensor control, cyl. 1-3 1B 1C 08 09
    145 91 YES Function, oxygen sensor control, cyl. 4-6 1B 1C 08 09
    146 92 internal index 105
    147 93 ??? Function, map cooling / internal index 106
    148 94 EWS 3.3 interface DME-EWS/Interface
    149 95 P0313 Error if tank is empty
    150 96 YES internal: Memory test Master F3 F4 FC FD
    151 97 YES internal: driver diagnostics chain F5 07 08 09
    152 98 YES internal: Communication master 06 07 FA 09
    153 99 internal index 87
    154 9A YES Crankcase breather 06 07 08 09
    155 9B YES internal: Adaption-EEPROM master F6 F0 F1 F2
    156 9C YES internal: Adaption-EEPROM Slave F6 F0 F1 F2
    157 9D YES internal: Memory test Slave F3 F4 FC FD
    158 9E P0606 internal: Resets Slave F8 F9 FA 09
    159 9F YES Internal DME fault: knock control 1 17 07 F7 09
    160 A0 YES Internal DME fault: knock control 2 17 07 F7 09
    161 A1 YES Internal DME fault: knock control signal path 06 07 0E 09
    162 A2 YES Camshaft sensor, bank 2: synchronization to crankshaft 06 07 08 E3
    163 A3 P0606 Reset DME possibly due to overspeed F8 F9 FA 09
    164 A4 ??? Atmospheric-pressure sensor / internal index 99
    165 A5 internal index 100
    166 A6 internal index 101
    167 A7 internal index 102
    168 A8 ??? Activation, fault lamp (Check Engine) / internal index 103
    169 A9 internal index 104
    170 AA YES Minimum flow of secondary air 23 24 25 09
    171 AB YES Function, secondary air injector valve EB 07 08 09
    172 AC VANOS admission pressure pump
    173 AD YES Continuous signal term. 50, starter switch EC 07 08 09
    174 AE P0172 Multiplicative mixture adaptation, cyl. 1-3 control limit reached C9 CA CB CC
    175 AF P0175 Multiplicative mixture adaptation, cyl. 4-6 control limit reached C9 CA CB CC
    176 B0 Abort, Tank leakage diagnosis, due to moisture
    177 B1 YES MIL lights up due to prompt from SMG 06 07 08 30
    178 B2 P0420 Catalytic converter conversion, cyl. 1-3 D7 07 08 09
    179 B3 P0430 Catalytic converter conversion, cyl. 4-6 D7 07 08 09
    180 B4 YES Tank leak detected D8 D9 08 DA
    181 B5 YES Fuel filler cap open/missing D8 D8 D8 D8
    182 B6 P0216 Over-temperature on injection driver 1 06 07 08 FB
    183 B7 P0200 Over-temperature on injection driver 2 06 07 08 FB
    184 B8 YES Function, inlet VANOS 18 19 C6 09
    185 B9 YES Function, exhaust VANOS 18 19 1A 09
    186 BA Ignition coil, cylinder 1
    187 BB Ignition coil, cylinder 2
    188 BC Ignition coil, cylinder 3
    189 BD Ignition coil, cylinder 4
    190 BE Ignition coil, cylinder 5
    191 BF Ignition coil, cylinder 6
    192 C0 Ignition coil, cylinder 7
    193 C1 Ignition coil, cylinder 8
    194 C2 Electric throttle, limp home program from cruise control mode – engine runs on ICV only.
    195 C3 YES Deviation, setpoint torque from actual torque C2 C3 C4 C5
    196 C4 P0301 Misfire, cyl.1, with cylinder cutout BD BA BB BC
    197 C5 P0302 Misfire, cyl.2, with cylinder cutout BD BA BB BC
    198 C6 P0303 Misfire, cyl.3, with cylinder cutout BD BA BB BC
    199 C7 P0304 Misfire, cyl.4, with cylinder cutout BD BA BB BC
    200 C8 P0305 Misfire, cyl.5, with cylinder cutout BD BA BB BC
    201 C9 P0306 Misfire, cyl.6, with cylinder cutout BD BA BB BC
    202 CA P0307 Misfire, cyl.7, with cylinder cutout BD BA BB BC
    203 CB P0308 Misfire, cyl.8, with cylinder cutout BD BA BB BC
    204 CC P0300,P0363 Misfiring, several cylinders, with cylinder cutout BD BA BB BC
    205 CD P0301 Misfire, cyl.1, without cylinder cutout BD BF BE BC
    206 CE P0302 Misfire, cyl.2, without cylinder cutout BD BF BE BC
    207 CF P0303 Misfire, cyl.3, without cylinder cutout BD BF BE BC
    208 D0 P0304 Misfire, cyl.4, without cylinder cutout BD BF BE BC
    209 D1 P0305 Misfire, cyl.5, without cylinder cutout BD BF BE BC
    210 D2 P0306 Misfire, cyl.6, without cylinder cutout BD BF BE BC
    211 D3 P0307 Misfire, cyl.7, without cylinder cutout BD BF BE BC
    212 D4 P0308 Misfire, cyl.8, without cylinder cutout BD BF BE BC
    213 D5 P0300,P0316 Misfiring of several cylinders without cylinder cutout BD BF BE BC
    214 D6 YES Oxygen sensor before cat., cyl. 1-3, period duration D2 D3 08 09
    215 D7 YES Oxygen sensor before cat., cyl. 4-6, period duration D2 D3 08 09
    216 D8 YES Oxygen sensor before cat., cyl. 1-3, jump time CD CE 08 09
    217 D9 YES Oxygen sensor before cat., cyl. 4-6, jump time CD CE 08 09
    218 DA YES Oxygen sensor before cat., cyl. 1-3, signal deviation CF 07 08 09
    219 DB YES Oxygen sensor before cat., cyl. 4-6, signal deviation CF 07 08 09
    220 DC DME internal processor check
    221 DD YES System test, crankcase breather 06 EA 08 09
    222 DE YES No CAN-bus signal from supplementary control module 06 07 0C 09
    223 DF YES Charge-air pressure sensor, range check 06 07 08 40
    224 E0 YES plausibility loading signal 06 07 08 09
    225 E1 YES Outside temperature from instrument cluster implausible 06 07 60 61
    226 E2 YES Time value from instrument cluster implausible 06 07 62 63
    227 E3 ??? Activation, battery disconnecting switch / internal index 79
    228 E4 Electric throttle: limit violation
    229 E5 Electric throttle: control deviation
    230 E6 YES Electric throttle: setpoint/actual-value monitoring E0 E1 1F 1A
    231 E7 YES DME internal processor check 06 07 FA 09
    232 E8 Function test, tank ventilation system
    233 E9 ??? Activation, automatic starting device / internal index 85
      Code variations. To be used as reference for the last 4 columns of the table above.
      00 --
      01 Error after debouncing stored
      02 Error present
      03 Error not present
      04 Static error
      05 Sporadic error
      06 0001 - Short circuit to battery or value too high
      07 0010 - Short circuit to ground or value too small
      08 0100 - Broken wire / Value missing
      09 1000 - Condition / value implausible / over-temperature
      0A OBD exhaust relevant error
      0B implausible telegram content
      0C telegram not received
      0D too many messages
      0E Timeout
      0F open circuit or short circuit
      10 Start value defective
      11 Changing code lost
      12 Start value empty
      13 Manipulation
      14 Secondary circuit
      15 Primary circuit
      16 Signal level too low
      17 Signalpegel too high
      18 Actual value too high
      19 Actual value too low
      1A Nominal value not reached
      1B Upper regulator limit
      1C Lower regulator limit
      1D Grip at stop
      1E No grip while driving
      1F closing not correct
      20 Error security disconnection
      21 Closing coil defective
      22 Nominal/actual-comparison error
      23 Bench 1 too small
      24 Bench 2 too small
      25 both Benches too small
      30 MIL-requirement by SMG
      40 preasure intaken manifold > preasure environment at running engine
      50 T-increase too low or coolant warmer than engine
      60 error detection environmental temperature inside CAN-telegramm
      61 detection hanging sensor after long vehicle-non-driving-time
      62 implausible vehicle-non-driving-time
      63 implausible relative time during engine operation
      B0 Acceleration n to v
      B1 Deceleration switch off
      B2 Maximum engine speed
      B3 v-signal not plausible
      B4 Format error
      B5 Redundancy comparison
      B6 unexpected code
      B7 no toggle bit
      BA within FTP-cycle
      BB outside FTP-cycle
      BC in 1st measuring interval warm up
      BD warm up in opearting interval
      BE in 1st measuring interval
      BF in operating interval
      C0 Cat. damaging
      C1 exhaust worsening
      C2 Zero moment value check
      C3 Nominal/Actual moment check
      C4 Minimal engine moment area check
      C5 Engine moment area check
      C6 no pressure
      C9 Idle speed-MAX-error
      CA Idle speed-MIN-error
      CB Part load-MAX-error
      CC Part load-MIN-error
      CD Lean rise time too long
      CE Rich rise time too long
      CF Sensor movement too small
      D0 TV-shift nach cat too high
      D1 TV-shift before cat too high
      D2 Period length too high
      D3 Period length too small
      D4 no positive gradient
      D5 no negative gradient
      D6 Sensor voltage after movement implausible
      D7 Limitation exceeded
      D8 Rough leackage
      D9 Fine leackage
      DA Current curve not plausible
      DB Sensor voltage when re-activated
      DC TV-value too high
      DD TV-value too small
      DE Sensor voltage too rich after removing power
      DF Sensor voltage too lean after re-starting
      E0 pinch open
      E1 pinch closed
      E2 Leak air
      E3 Signal position not plausible
      E4 Raising ramp not plausible
      E5 Signal unplausibel against filling
      E6 Position regulator does not react
      E7 Adaption run does not take place
      E8 Deviation against 2nd poti too high
      E9 DSC reports V-error
      EA Flow too small
      EB Valve pinches
      EC Switch pinches
      ED Pulse width too large
      EE Pulse width too small
      EF Heating broken
      F0 No adaptions and calibration values saved
      F1 Error memory check sum wrong
      F2 No error memory saved
      F3 RAM-cell
      F4 ROM-cell/Manipulation
      F5 Check word not recognized
      F6 No EWS-change code stored
      F7 internal interface disturbed
      F8 Watchdog-Reset
      F9 Software-Reset
      FA Abort/Function-Time out
      FB Driver disconnection because of over load
      FC ADC-register
      FD SIM-register
      FE Reference current too small
      FF Reference current too high
        Cross-reference table. If you have one scanner, but the code is not listed, or vague, here are what different scanners define them as:
        Column 1 is the error code # in decimal.
        Column 2 is the error code # in hex.
        Column 3 is the error as INPA would describe it.
        Column 4 is the error as DIS would describe it.
        Column 5 is the error as it is described in the PEAKE reader manual Table 18.
        001 0x01 Relay fuel pump Driver/relay, fuel pump Fuel pump relay
        002 0x02 Idling control closing coil Idle speed control valve, NO winding Idle speed actuator (close)
        003 0x03 Intake valve 1 Fuel injector, cyl. 1 Fuel injector, Cyl #1
        004 0x04 Intake valve 3 Fuel injector, cyl. 3 Fuel injector. Cyl #3
        005 0x05 Intake valve 2 Fuel injector, cyl. 2 Fuel Injector, Cyl #2
        006 0x06 Time out SMG-CAN Timeout SMG-CAN Timeout SMG-CAN
        007 0x07 EVANOS1-Hall sensor Signal, camshaft sensor, inlet Intake camshaft position sensor, Cyl #1-4
        008 0x08 EVANOS2-Hall sensor Signal, camshaft sensor, outlet Intake camshaft position sensor, Cy\ #5·8
        009 0x09 Knocking sensor 1 Signal, knock sensor, cyl. 1-2 Knock sensor, Cyl #1·2
        010 0x0A AVANOS1-Hall sensor Signal, camshaft sensor, exhaust Exhaust camshaft position sensor, Cyl #1-4
        011 0x0B AVANOS2-Hall sensor VANOS test Exhaust camshaft position sensor, Cyl #5-8
        012 0x0C Lambda sensor 2 before cat Signal, oxygen sensor before cat., cyl. 4-6 PreCat 02 sensor, Cyl #5·8
        013 0x0D Lambda sensor 1 before cat Signal, oxygen sensor before cat., cyl. 1-3 PreCat 02 sensor. Cy\ #1-4
        014 0x0E LDP-Heater Tank small leak
        015 0x0F Synchronisation CS-sensor 1 with KW Camshaft sensor, synchronization to crankshaft CrankshafUCamshaft position correlation, Cyl #1-4
        016 0x10 KW-inductive sensor Signal, crankshaft sensor Crankshaft sensor
        017 0x11 SMG switching process SMG shift sequence
        018 0x12 GKS driver VANOS pressure-accumulator valve Map controlled thermostat actuator
        019 0x13 Secondary air pump relay Relay, secondary air pump Secondary air pump relay
        020 0x14 Start relay Start relay Starter relay
        021 0x15 AVANOS1-late valve Exhaust VANOS, retard valve Exhaust camshaft VANOS retard valve, Cyl #1 -4
        022 0x16 AVANOS1-early valve Exhaust VANOS, advance valve Exhaust camshaft VANOS advance valve, Cyl #1-4
        023 0x17 Ignition coil 2 Ignition coil, cyl. 2 Ignition Coil, Cyl #2
        024 0x18 Ignition coil 3 Ignition coil, cyl. 3 Ignition Coil, Cyl #3
        025 0x19 Ignition coil 1 Ignition coil, cyl. 1 Ignition Coil, Cyl #1
        026 0x1A Ignition coil 8 Ignition coil, cyl. 8 Ignition Coil, Cyl #8
        027 0x1B Tank leakage diagnosis valve DMTL changeover valve OM-TL SWitching valve
        028 0x1C GKS regulator Function, map cooling Map controlled thermostat control
        029 0x1D Idling control opening coil Idle speed control valve,NC-contact winding Idle speed actuator (open)
        030 0x1E Monitoring AD-converter Internal DME fault Control unit self-test. AID converter monitoring
        031 0x1F Intake valve 5 Fuel injector, cyl. 5 Fuel Injector, Cyl #5
        032 0x20 Intake valve 6 Fuel injector, cyl. 6 Fuel injector, Cyl #6
        033 0x21 Intake valve 4 Fuel injector, cyl. 4 Fuel injector, Cyl #4
        034 0x22 Intake valve 7 Fuel injector, cyl. 7 Fuel injector, Cyl #7
        035 0x23 Intake valve 8 Fuel injector, cyl. 8 Fuel injector, Cyl #8
        036 0x24 Tank ventilation valve Tank venting valve Evaporative emission purge control valve
        037 0x25 Lambda sensor heating 1 before cat. Oxygen sensor heater before cat., cyl. 1-3 PreCat 02 sensor heater control, Cyl #1-4
        038 0x26 Lambda sensor heating 2 before cat. Oxygen sensor heater before cat., cyl. 4-6 PreCat 02 sensor heater control, Cyl #5·8
        039 0x27 Lambda sensor heating 1 after cat. Oxygen sensor heater after cat., cyl. 1-3 AfterCat 02 sensor heater control, Cyl #1-4
        040 0x28 Lambda sensor heating 2 after cat. Oxygen sensor heater after cat., cyl. 4-6 AfterCat 02 sensor heater control, Cyl #5·8
        041 0x29 Air mass sensor 1 Signal, mass air flow sensor Air mass sensor, Cyl #1-4
        042 0x2A Direct speed input Road speed signal PIN 4-22 Vehicle speed input signal. hardwired A signal
        043 0x2B Cooling water outlet temperature sensor Signal, temperature sensor, radiator outlet Radiator outlet temperature sensor
        044 0x2C Signal active oil level sensor Signal, thermal oil level sensor Thermal oil level sensor
        045 0x2D EDK-hardware Electric throttle: servomotor Drive-by-wire throttle actuator driver
        046 0x2E Consumption signal output KVA Output, consumption signal KVA Fuel consumption (KVA) s1gnal output
        047 0x2F Engine speed signal output TD Output, engine-speed signal TD Engine RPM (TO) signal output
        048 0x30 Relay A/C compressor Interface, IHKA (E46)/relay, A/C compressor (E36/7) A/C Compressor relay
        049 0x31 internal index 95
        050 0x32 Ignition coil 4 Ignition coil, cyl. 4 Ignition Coil, Cyl #4
        051 0x33 Ignition coil 6 Ignition coil, cyl. 6 Ignition Coil. Cyl #6
        052 0x34 Ignition coil 5 Ignition coil, cyl. 5 Ignition Coil, Cyl #5
        053 0x35 Electronic fan Interface, electric fan (E46)/relay, electric fan, stage 2 (E36/7) Electronic fan (relay)
        054 0x36 Main relay for supply voltage System voltage, main relay Battery voltage behind main relay
        055 0x37 Ignition coil 7 Ignition coil, cyl. 7 Ignition Coil, Cyl #7
        056 0x38 internal index 96
        057 0x39 Air mass sensor 2 Signal, mass air flow sensor, left Air mass sensor, Cyl #5·8
        058 0x3A Sensor supply 1 Master Voltage supply, sensors 1 Sensor voltage supply 1
        059 0x3B Sensor supply 2 Master Voltage supply, sensors 2 Sensor voltage supply 2
        060 0x3C Pedal value sensor 1 Signal, pedal travel sensor 1 Pedal position sensor 1, master measurement
        061 0x3D Pedal value sensor 2 Signal, pedal travel sensor 2 Pedal position sensor 2, master measurement
        062 0x3E internal index 97
        063 0x3F Secondary air valve Secondary air valve Secondary air switching valve
        064 0x40 internal index 98 VANOS supplementary components
        065 0x41 Throttle valve pot. 2 Slave Signal, throttle potentiometer and el. throttle actuator Throttle position sensor 2, slave measurement
        066 0x42 EWS-interface EWS interface: no communication EWS interface
        067 0x43 EVANOS1-early valve Inlet VANOS, advance valve Intake camshaft VANOS advance valve, Cyl #1-4
        068 0x44 SMG safety concept SMG safety concept
        069 0x45 Knocking sensor 3 Signal, knock sensor, cyl. 3-4 Knock sensor, Cyl #5-6
        070 0x46 Knockingsensor 2 Signal, knock sensor, cyl. 5-6 Knock sensor, Cyl #3-4
        071 0x47 Knocking sensor 4 Switch, driving dynamics Knock sensor, Cyl #7-8
        072 0x48 EVANOS1-late valve Inlet VANOS, retard valve Intake camshaft VANOS retard valve, Cyl #1-4
        073 0x49 Air mass to DKG-adjustment not plausible Signal, mass air flow sensor, implausible Air mass sensor, plausibility
        074 0x4A EVANOS2-early valve3 Inlet VANOS, bank 2, advance valve Intake camshaft VANOS advance valve, Cyl #5-8
        075 0x4B EVANOS2-late valve Inlet VANOS, bank 2, retard valve Intake camshaft VANOS retard valve, Cyl #5·8
        076 0x4C internal: Surrounding pressure sensor Ambient pressure sensor (DME internal) Ambient pressure sensor
        077 0x4D Manifold air temperature sensor Signal, temperature sensor, intake air Intake air temperature sensor
        078 0x4E Cooling water temperature sensorB Signal, temperature sensor, coolant Coolant temperature sensor
        079 0x4F Exhaust temperature sensor Signal, temperature sensor, exhaust gas Exhaust gas temperature sensor
        080 0x50 Switch chain grip Switch chain, frictional connection Switch-chain grip
        081 0x51 MFL-interface Interface, multifunction steering wheel (E46) / steering-column stalk (E36/7) MFL interface signal
        082 0x52 Exhaust valve Activation, exhaust flap Muffler flap
        083 0x53 AVANOS2-early valve Exhaust VANOS, bank 2, advance valve Exhaust camshaft VANOS advance valve, Cyl #5-8
        084 0x54 AVANOS2-late valve Exhaust VANOS, bank 2, retard valve Exhaust camshaft VANOS retard valve, Cyl #5-8
        085 0x55 EDK-sensor Signal, throttle-valve potentiometer Throttle position sensor, master measurement
        086 0x56 CAN-Bus DME No CAN-bus signal to DME CAN bus offline
        087 0x57 Lambda sensor 1 after cat. Signal, oxygen sensor after cat., cyl. 1-3 AfterCat 02 sensor voltage, Cyl #1-4
        088 0x58 Lambda sensor 2 after cat. Signal, oxygen sensor after cat., cyl. 4-6 AfterCat 02 sensor voltage, Cyl #5·8
        089 0x59 internal index 240 Internal DME fault Control unit self-test, Safety Concept slave check
        090 0x5A Pre-cat sensor 1 TV-shift Trim control, cyl. 1-3 PreCat 02 sensor aging, Cy\ #1-4
        091 0x5B Pre-cat sensor 2 TV-shift Trim control, cyl. 4-6 PreCat 02 sensor aging, Cyl #5-8
        092 0x5C Post-cat sensor 1 voltage monitoring Oxygen sensor after cat., cyl. 1-3: voltage monitoring AfterCat 02 sensor aging, Cyl #1-4
        093 0x5D Post-cat sensor 2 voltage monitoring Oxygen sensor after cat., cyl. 4-6: voltage monitoring AfterCat 02 sensor aging, Cyl #5-8
        094 0x5E internal index 241 Inlet-VANOS adaptation
        095 0x5F internal index 242 Exhaust-VANOS adaptation
        096 0x60 plausibility coolant outtaken temperature Radiator outlet temperature implausible
        097 0x61 internal index 244
        098 0x62 internal index 245
        099 0x63 internal index 246 Internal DME fault Control unit self-test, Safety Concept master check
        100 0x64 Tire pressure left front Internal error Tire pressure left front
        Continued on next post.
          101 0x65 Tire pressure right front Signal, tire pressure, front right Tire pressure right front
          102 0x66 Tire pressure right back Signal, tire pressure, rear right Tire pressure right back
          103 0x67 Tire pressure left back Signal, tire pressure, rear left Tire pressure left back
          104 0x68 internal index 86 ??? Wrong values in fault memory
          105 0x69 Plausibility engine temperature Signal, engine temperature implausible. Temperature sensor possibly tampered with or faulty or thermostat jammed. Engine coolant temperature, Plausibility
          106 0x6A Brake light switch Signal, brake light switch Brake light switch
          107 0x6B Self test EGAS-actuator Electric throttle: self-test Control unit self-test, pre-drive check of drive-by-wire system
          108 0x6C Oil valve left Activation, oil circuit changeover valve, left Switching valve oil circuit left
          109 0x6D Oil valve right Activation, oil circuit changeover valve, right Switching valve oil circuit right
          110 0x6E LED dynamic drive switch Function light, switch, driving dynamics Sport switch LED indicator
          111 0x6F Pedal value comparison 1 Pedal travel sensor, comparison fault Pedal position sensor 1, cross check
          112 0x70 Pedal value comparison 2 Pedal-position sensor, comparison fault Pedal position sensor 2, cross check
          113 0x71 EVANOS2-regulation Function, inlet VANOS, bank 2 Intake camshaft VANOS position control, Cyl #5-8
          114 0x72 AVANOS2-regulation Function, exhaust VANOS, bank 2 Exhaust camshaft VANOS position control,Cyl #5-8
          115 0x73 internal: ECU-temperature Sensor, control module temp. (DME internal), or button, tire pressure Control unit self-test, internal ECU temperature
          116 0x74 Servotronik valve measurement of current Activation, valve, Servotronic Servotronic valve current
          117 0x75 Servotronik measurement of speed signal Road speed signal via CAN Servotronic speed sig nat
          118 0x76 Throttle valve pot. 1 Electric throttle: signal, potentiometer, throttle Throttle position sensor 1
          119 0x77 Throttle valve pot. 2 Signal, potentiometer, servomotor Throttle position sensor 2
          120 0x78 Comparison throttle valve pot. Electric throttle: potentiometer, signal comparison Throttle position sensors, cross check
          121 0x79 Both throttle valve pots. Electric throttle: both potentiometers faulty Throttle position sensors, both bad
          122 0x7A internal: Master processor check DME internal processor check Control unit self-test, master processor
          123 0x7B Bus-Off local SMG-CAN No CAN-bus signal from SMG Bus offline, SMG-CAN
          124 0x7C potentiometer sound flap GKS Activation, active engine mount Active engine bearing
          125 0x7D Spoiler adjustment/TOG-lamp Function lamp, oil level Spoiler adjustment
          126 0x7E EKP-crash-disconnection Crash deactivation, fuel pump Fuel pump crash shut-off
          127 0x7F Tank leakage diagnosis module Activation, DMTL pump OM-TL module
          128 0x80 Deviation idling speed Deviation, idle speed Idle speed deviation
          129 0x81 KAT protection activated at empty petrol tank Cat. protection function due to empty tank or lack of fuel
          130 0x82 EWS-signal manipulation EWS 3.3 tampering protection EWS signal, manipulation detected
          131 0x83 DSC-intervention not plausible DSC intervention implausible DSC intervention, plausibility
          132 0x84 Time out DSC-message CAN timeout DSC DSC message timeout
          133 0x85 Time out LWS-message CAN timeout, steering angle sensor Steering angle sensor message timeout
          134 0x86 Time out KOMBI-message CAN timeout, instrument cluster Instrument Cluster message timeout
          135 0x87 Both V-Signal sources No road speed signal Vehicle speed signals (both Discrete & CAN)
          136 0x88 Idle speed regulator Function, idle speed control Idle speed controller
          137 0x89 Jet stream pump Suction-jet pump Jet stream pump
          138 0x8A Differential lock Activation, differential lock Differential lock
          139 0x8B Cruise control system nterruption, cruise-control operation Cruise control system
          140 0x8C Engine noise Knock control deactivated/knock protection Engine noise too high
          141 0x8D Filling value plausibilisation Tank fill level implausible Fuel level, plausibility
          142 0x8E System jet stream pump System check, suction jet pump for brake boosting
          143 0x8F E-box-fan Activation, electronics box fan E-box-fan
          144 0x90 Lambda regulator 1 Function, oxygen sensor control, cyl. 1-3 Fuel control, Cyl #1-4
          145 0x91 Lambda regulator 2 Function, oxygen sensor control, cyl. 4-6 Fuel control, Cyl #5·8
          146 0x92 internal index 105
          147 0x93 internal index 106 ??? Function, map cooling
          148 0x94 internal index 107 EWS 3.3 interface DME-EWS/Interface, electronic engine immobiliser
          149 0x95 Error if tank is empty Fault with empty tank Misfire w/ empty fuel tank
          150 0x96 internal: Memory test Master DME memory fault Control unit self-test, memory test master
          151 0x97 internal: driver diagnostics chain Internal DME fault Control unit se~·test, driver diagnostics chain
          152 0x98 internal: Communication master Control unit self-test, communication master
          153 0x99 internal index 87
          154 0x9A crankcase venting Crankcase breather
          155 0x9B internal: Adaption-EEPROM master Storing adaptation values not possible Control unit self-test, adaption EEPROM master
          156 0x9C internal: Adaption-EEPROM Slave Storing adaptation values not possible Control unit self-test, adaption EEPROM slave
          157 0x9D internal: Memory test Slave DME memory fault Control unit self-test, memory test slave
          158 0x9E internal: Resets Slave Reset DME possibly due to overspeed Control unit se~·test, communication slave
          159 0x9F Knock IC 1 Internal DME fault: knock control Control unit self-test, knock detection IC 1
          160 0xA0 Knock IC 2 Internal DME fault: knock control Control unit self-test, knock detection IC 2
          161 0xA1 internal: Knock signal path Internal DME fault: knock control Knock control
          162 0xA2 Synchronisation CS-sensor 2 with KW Camshaft sensor, bank 2: synchronization to crankshaft CrankshafUCamshaft position correlation, Cyl #5-8
          163 0xA3 internal: Resets Master Reset DME possibly due to overspeed Control unit self-test, master resets
          164 0xA4 internal index 99 ??? Atmospheric-pressure sensor
          165 0xA5 internal index 100
          166 0xA6 internal index 101
          167 0xA7 internal index 102
          168 0xA8 internal index 103 ??? Activation, fault lamp (Check Engine)
          169 0xA9 internal index 104
          170 0xAA Minimum flow of secondary air Secondary air quantity too low Secondary air system, flow too low
          171 0xAB Secondary air valve stuck Function, secondary air injector valve Secondary air system, valve sticking
          172 0xAC Vanos-pressure storage valve VANOS admission pressure pump VANOS pressure storage valve
          173 0xAD KL50 starter switch0 Continuous signal term. 50, starter switch Starter switch input
          174 0xAE Fuel system diagnosis 1 Multiplicative mixture adaptation, cyl. 1-3 control limit reached Air-fuel adaptation, Cyl #1-4
          175 0xAF Fuel system diagnosis 2 Multiplicative mixture adaptation, cyl. 4-6 control limit reached Air-fuel adaptation, Cyl #5-8
          176 0xB0 internal index 174 Abort, Tank leakage diagnosis, due to moisture Air-fuel adaptation at idle, Cyl #1-4
          177 0xB1 MIL external info MIL lights up due to prompt from SMG Air-fuel adaptation at idle, Cyl #5·8
          178 0xB2 KAT-conversion 1 Catalytic converter conversion, cyl. 1-3 Catalyst system efficiency, Cyl #1·4
          179 0xB3 KAT-conversion 2 Catalytic converter conversion, cyl. 4-6 Catalyst system efficiency, Cyl #5-8
          180 0xB4 Tank leak Tank leak detected Tank leak detected
          181 0xB5 Info Tank cap missing Fuel filler cap open/missing Filler cap open
          182 0xB6 Over-temperature on injection driver 1 Internal DME fault Injection driver 1, over temp.
          183 0xB7 Over-temperature on injection driver 2 Internal DME fault Injection driver 2, over temp.
          184 0xB8 EVANOS1 regulation Function, inlet VANOS Intake camshaft VANOS position control, Cyl #1-4
          185 0xB9 AVANOS1 regulation Function, exhaust VANOS Exhaust camshaft VANOS pos1bon control Cy1 #1-4
          186 0xBA Ignition coil, cylinder 1 Ignition output stage, Cy1 #1
          187 0xBB Ignition coil, cylinder 2 Ignition output stage. Cy1 #2
          188 0xBC Ignition coil, cylinder 3 Ignition output stage, Cy1 #3
          189 0xBD Ignition coil, cylinder 4 Ignition output stage, Cyl #4
          190 0xBE Ignition coil, cylinder 5 Ignition output stage, Cy1 #5
          191 0xBF Ignition coil, cylinder 6 Ignition output stage, Cyl #6
          192 0xC0 Ignition coil, cylinder 7 Ignition output stage, Cyl #7
          193 0xC1 Ignition coil, cylinder 8 Ignition output stage, Cy1 #8
          194 0xC2 Safety check disconnection FGR Electric throttle, limp home program from cruise control mode Control un1t self-test. cruise control shut-off
          195 0xC3 Monitoring torque manager Deviation, setpoint torque from actual torque Control unit self-test. torque manager mon1tonng
          196 0xC4 Misfire cyl. 1 cat.-dam. Misfire, cyl.1, with cylinder cutout Misfire. Cy1 #1
          197 0xC5 Misfire cyl. 2 cat.-dam. Misfire, cyl.2, with cylinder cutout Misfire. Cy1 #2
          198 0xC6 Misfire cyl. 3 cat.-dam. Misfire, cyl.3, with cylinder cutout Misfire Cy1 #3
          199 0xC7 Misfire cyl. 4 cat.-dam. Misfire, cyl.4, with cylinder cutout Misfire. Cy1 #4
          200 0xC8 Misfire cyl. 5 cat.-dam. Misfire, cyl.5, with cylinder cutout Misfire. Cyl #5
            201 0xC9 Misfire cyl. 6 cat.-dam. Misfire, cyl.6, with cylinder cutout Misfire, Cyl #6
            202 0xCA Misfire cyl. 7 cat.-dam. Misfire, cyl.7, with cylinder cutout Misfire. Cyl #7
            203 0xCB Misfire cyl. 8 cat.-dam. Misfire, cyl.8, with cylinder cutout Misfire. Cyl #8
            204 0xCC Misfire of multiple cyl. cat.-dam. Misfiring, several cylinders, with cylinder cutout W.sfire mulbple cylmders
            205 0xCD Misfire cyl. 1 Exhaust Misfire, cyl.1, without cylinder cutout Msfire dunng warm-up. Cy1 #1
            206 0xCE Misfire cyl. 2 Exhaust Misfire, cyl.2, without cylinder cutout Msfire dunng warm-up, Cy1 #2
            207 0xCF Misfire cyl. 3 Exhaust Misfire, cyl.3, without cylinder cutout Misfire dunng warm-up, Cy1 #3
            208 0xD0 Misfire cyl. 4 Exhaust Misfire, cyl.4, without cylinder cutout Misfire dunng warm-up, Cy1 #4
            209 0xD1 Misfire cyl. 5 Exhaust Misfire, cyl.5, without cylinder cutout Misfire dunng warm-up, Cyl #5
            210 0xD2 Misfire cyl. 6 Exhaust Misfire, cyl.6, without cylinder cutout Misfire dunng warm-up, Cyl #fj
            211 0xD3 Misfire cyl. 7 Exhaust Misfire, cyl.7, without cylinder cutout Misfire during warm-up, Cyl #7
            212 0xD4 Misfire cyl. 8 Exhaust Misfire, cyl.8, without cylinder cutout Misfire dunng warm-up, Cyl #8
            213 0xD5 Misfire of multiple cyl. Exhaust Misfiring of several cylinders without cylinder cutout Misfire dunng warm-up, multiple cylinders
            214 0xD6 Pre-cat sensor 1 period length Oxygen sensor before cat., cyl. 1-3, period duration PreCat 02 sensor slow response. Cyl #1-4
            215 0xD7 Pre-cat sensor 2 period length Oxygen sensor before cat., cyl. 4-6, period duration PreCat 02 sensor slow response Cy1 #5-8
            216 0xD8 Pre-cat sensor 1 rise time Oxygen sensor before cat., cyl. 1-3, jump time PreCat 02 sensor slow switchmg (nch too lean) Cyl #1-4
            217 0xD9 Pre-cat sensor 2 rise time Oxygen sensor before cat., cyl. 4-6, jump time PreCat 02 sensor slow swllchmg (nch too lean), Cyl #5-8
            218 0xDA Pre-cat sensor 1 signal displacement Oxygen sensor before cat., cyl. 1-3, signal deviation PreCat 02 sensor signal Size/amplitude, Cyl #1-4
            219 0xDB Pre-cat sensor 2 signal displacement Oxygen sensor before cat., cyl. 4-6, signal deviation PreCat 02 sensor signal size/amplitude, Cyl #5-8
            220 0xDC internal index 235 DME internal processor check
            221 0xDD systemcheck crankcase venting System test, crankcase breather
            222 0xDE CAN timeout ZSG No CAN-bus signal from supplementary control module
            223 0xDF preasure intaken manifold Charge-air pressure sensor, range check
            224 0xE0 plausibility loading signal
            225 0xE1 environmental temperature Outside temperature from instrument cluster implausible
            226 0xE2 Kombi relative time Time value from instrument cluster implausible
            227 0xE3 internal index 79 ??? Activation, battery disconnecting switch
            228 0xE4 EGAS-actuator Electric throttle: limit violation Drie-by-Wire, throttle control failure
            229 0xE5 EGAS-regulation Electric throttle: control deviation Drie-by-Wire. throttle control fa11ure
            230 0xE6 EGAS-Nominal/actual-comparison Electric throttle: setpoint/actual-value monitoring Drie-by-Wire. throttle poSition failure
            231 0xE7 internal: slave processor check DME internal processor check Control un1t self-test, slave processor check
            232 0xE8 Function check TEV Function test, tank ventilation system Evaporatve emssions purge valve functional check
            233 0xE9 internal index 85 ??? Activation, automatic starting device
            234 0xEA
            235 0xEB
            236 0xEC
            237 0xED
            238 0xEE
            239 0xEF
            240 0xF0
            241 0xF1
            242 0xF2
            243 0xF3
            244 0xF4
            245 0xF5
            246 0xF6
            247 0xF7 VANOS pressure accumulator valve
            248 0xF8 Intake camshaft VANOS moving time, Cyl #1-4
            249 0xF9 Exhaust camshaft VANOS moving bme. Cyl #1-4
            250 0xFA Intake camshaft VANOS sealing Cyl #1-4
            251 0xFB Exhaust camshaft VANOS sealing Cy1 #1-4
            252 0xFC Intake camshaft VANOS lllO'IIng time. Cyl #5-8
            253 0xFD Exhaust camshaft VANOS mOVIng bme, Cyl #5-8
            254 0xFE Intake camshaft VANOS sealing, Cyl #5-8
            255 0xFF Exhaust camshaft VANOS seal1ng. Cyl #5-8
              Awesome, do you have the list of the SW variant and their binary address? I have the DTC location PDF saved with the full strands, but there’s no descriptions in that. It’s just all hex.
                If someone has the table with the decimal, hex, and hex code strings that would be insanely useful. As well as the table PITTM3RR requested.
                2003 E46 M3 TiAg/Cinnamon 6MT
                2005 E46 330i ZHP Imola/Sand
                Instagram:@thegenius46m
                  Copy from p0lar on the old M3F There are two main methods by which DTCs (Diagnostic Trouble Codes) are commonly suppressed within the MSS50/MSS52/MSS54/MSS54HP, and several alternative methods. Let's start by learning how to identify a DTC string within the DME. A firm understanding of the DTC errors and their respective
                    There you go, here's the entire excel sheet, with the deletion strategies. Rename the file to extension "xlsx" instead of "doc" and use it as an excel file.
                    Enjoy.
                    385.7whp 288.8 wtq :
                    -CSL airbox ( custom)
                    -280 272 Cat cams
                    -Custom SSV2, modified for a bigger collector
                    -Custom Section 1 2 and 3: oversized to 2.5 inch and en E9xM Xpipe
                    -TMS pullies
                    -Electric Fan
                    -HTE performance Tune :P
                    PM for performance Tunes
                    IG: https://www.instagram.com/hte_performance_tuning/
                      Hello
                      Been searching and coming up empty. Maybe doesn't exist?
                      Anyone know what the "hex" error codes are for following lean faults?
                      P0171 System Too Lean (Bank 1)
                      P0174 System Too Lean (Bank 2)
                      Above tables do show the hex error codes for the rich mixtures,
                      P0172 System Too Rich (Bank 1)
                      P0175 System Too Rich (Bank 2)
