I recently had the entire cooling system refresh done (all OEM) and since then, car runs fine in normal temps but as soon as I do a couple of hard runs, the temp needle begins creeping towards red. It never happened prior to the refresh. Any idea what could be causing this? Air in the system or possibly something else? Thanks.
Coolant Temp Creep to Red on Hard Acceleration
Probably air in the system.06 ZCP SMG | HTE CSL MAP QuaranTune | SL CSL Airbox | Eventuri Scoop | DMG Strut Bar | RE El Diablo | CPI Euro200R | AP Headers | Porsche BBK | ST XTA | TMS 3-Pulleys/F-Sway/Mono FCAB | AKG Trans/diff/Subframe/RTAB | SPL RCA | SGT SCZA Trunk | ACL | Beisan | Redish | AFD E85 |
Budget CSL MAP Conversion
At operating temperature, reach down and grab the rad lower hose to see how hot it is. Can you hold it in your hand for 1 minute with no pain? If it is not hot then there is not enough coolant flow through the rad, hence overheated.Originally posted by ViN View Postbut as soon as I do a couple of hard runs, the temp needle begins creeping towards red..
System is self bleeding BUT maybe air is trapped in heater core if you never opened it after the flush?DD: /// 2011.5 Jerez/bamboo E90 M3 · DCT · Slicktop · Instagram
