I have an 02 coupe with bixenons looking to replacek both headlight assemblies due to broken tabs. Will any post 02 build bixenons be compatible with my lcm- or are there any nuances i should be aware of?
Compatible headlights for 2002
Last edited by lemoose; 07-09-2021, 08:41 AM.2002 TiAg M3 Coupe (SMG to 6spd), 2003 Jet Black M5
https://www.instagram.com/individual_throttle_buddies/Tags: None
No headlamp differences 2002-06 on the M, and the pre-facelift (2002-3/03) garden variety 3 series cpe/vert passenger side lamp is the same. Driver side headlamp on a non-M 3-series cpe/vert can be modified to work on an M3 by extending the wiring for the ballast to allow mounting on the fender apron (it's mounted on the headlamp assembly in the non-M). The LCM won't care what they came out of if you're replacing like for like.
Sent from my SM-G988U using Tapatalk
Thanks! Thats what my further research was pointing to but definitely wanted to make sure2002 TiAg M3 Coupe (SMG to 6spd), 2003 Jet Black M5
I have an 02 and im pretty certain its bixenon unless im mistaken? Both headlights and highbeams come from the outer xenon bulbOriginally posted by jet_dogg View PostThe bi-xenons came out around 3/03 I believe and the lenses are different though not materially.2002 TiAg M3 Coupe (SMG to 6spd), 2003 Jet Black M5
