Also it has to do with the geographic characteristics of where you drive. In the US where everything is flat I guess stock gears maybe fine, where I am, you rarely can do 100mph, our roads are very steep and curved, so shorter gearing make the car so much better
Differential Time, 3.91 vs 4.10 on 6 speed ZCP
Originally posted by Silbergrau metallic View PostSo! before I spend $5000 plus
Could you please share what is the reason for you to change the stock diff ?
What purpose/s are you after ?
Regards,
Anri
Hi,
Regards,
Anri
Originally posted by maupineda View PostAlso it has to do with the geographic characteristics of where you drive. In the US where everything is flat I guess stock gears maybe fine, where I am, you rarely can do 100mph, our roads are very steep and curved, so shorter gearing make the car so much better
- Likes 2
Bottom line, it's subjective. I have the 3.91 gears and love them. The bump in cruising RPM (at 80-90 mph) was not a problem as some report, but I do think it's near the cusp of being tolerable. For predominantly highway driving, I think the 3.91s are as much as I would want to go. In the city, or certain track work, I can see value in the 4.10s. But again, that's my personal take on it. I, too, find the stock gears a bit too tall.
My track only M3 came with 4.10s, and I moved it back to stock. I found the constant shifting annoying and slower.
I love the stock gearing on track. You’re overwhelmingly in 3rd and 4th, which don’t require any sideways force to shift into— so no risk of money shifts.
On the rare occasion there’s a super slow speed corner that needs 2nd gear, I wouldn’t want it to be any shorter.
- Likes 2
If you have a loud exhaust and street drive it...a shorter diff is going increase the revs and noise. Something to consider. You will certainly notice the difference with a 3.91. But 3.91 vs 4.10 for street isn't that different and likely won't matter with a 6 speed.
For those that swapped in 5 speeds (like me), this is more of a critical decision because there is a trade off in top speed.
If you have an SMG and plan to keep it SMG, it's an easy decision. Go with a 4.10 because paddle shifting.
I went with 3.91 as I was rebuilding my diff and installing a Drexler Motorsport core... it was very much a "while I'm here" type change as if I didn't do it then I would never do it.
It's hard for me to fully capture my thoughts as I need a proper custom tune (imminent) to fully asses, but in general I liked it early on, although my car had been off the road for ~2yrs and had a shopping list of mods and an engine rebuild so its hard to nail down individual changes.
Over time I have moved to the fence... part of my likes it, its a bit more lively and thats fun, but part of me also thinks it was pointless... the increased revs at slower speeds around the street is off putting for my wife and over time can feel obnoxious putting around the streets. I will reserve my full assessment for when I get a proper custom tune and finally get to start hitting the track... I do believe it will come into it's own when i enter Tarmac Rally events but until then I'll stay on the fence... I don't like it enough to advocate for it, yet I also don't dislike it enough to not advocate for it or consider removing it.
I would say if you are on the fence its worth saving your money and spending it elsewhere... I feel like unless you are tracking the car and feel like you are missing corner exit torque and feel like that is something that would support your driving style or the tracks you drive on then its potentially not worth it but thats just a thought.
I’m working w a shop to swap in a 5 speed and 4.10 for my track car. Kinda excited to see how it compares. I went with their recommended setup that they run on their shop cars.
I had a buddy who tried 3.91 with a 6 speed and he said he didn’t like it… def appears to be a personal preference thing. He said he’ll be doing a 5 speed with 4.10’s.
Sent from my iPhone using Tapatalk2018 Grigio Telesto F80 M3 DCT | :: Bone Stock ::
Originally posted by Obioban View PostMy track only M3 came with 4.10s6MT SLICKTOP - OE CSL Wheels - OE CSL Brakes - CSL Rack - CSL Trunk - CSL Diffuser - AA Tune - AA Pulleys- AS 40% SSK - 4.10 Motorsport Diff - Bilstein PSS9s - H&R Swaybars - CSL Lip - Gruppe M CF Intake - Supersprint - M Track Mode
Not sure how true this is, but a shop tech said that the 4.10s make more gear whine than the 3.91s because the gears are cut straighter. I think the 3.91s would be nice for a street car that sees a lot of uphill twisty roads. In 2nd gear, the revs can sometimes fall to 2k rpm on those slow, uphill, tight turns.
Originally posted by Slideways View PostNot sure how true this is, but a shop tech said that the 4.10s make more gear whine than the 3.91s because the gears are cut straighter. .
Originally posted by Obioban View PostI swapped out my LSD for a wavetrac, but kept final drive ratio stock. BMW just perfectly nailed it with the stock gearing, IMO.
