Belligerent TPM light !
    No matter how many times I reset the light, it comes back with a vengeance.
    My procedure:
    1) Press the TPM button (indicator in instrument cluster goes yellow)
    2) Start driving slowly
    3) Press and hold the button again (long press)
    After this procedure the indicator clears, but without fail has come back on numerous occasions!
    Any help is welcome!
    Installed square APEX ARC-8 18x9.5 ET35, 12mm spacers in the rear with new 4 265/35/18 Michelin Sport A/S 3+ all around...nothing but red tpms light since install. I’ll reset and comes back after a few minutes of driving. Went back to the shop and all checked out as far as pressure and no flat tires. Any ideas or is this a
      Thats not how TPMS is reset. Use procedure linked above or read your manual.
        I'll add:
        TMPS is coming on for a reason. You need to find the reason and fix it first. Then check pressures. Then use the re-learn procedure.
        If you don't fix the problem - the proper re-learn process will do nothing.
          If all else fails RTFM.
            My VMR wheels would leak.
            Early on, the tpms icon would come on yellow.
            I would reset by following the manual, but later discovered that I only had to keep the reset button depressed for 5 seconds. The icon illumuninates as it should....Cheap ass wheels.
            15k miles later and the icon comes on red.
            You'll be nagged by the dash until you fix the pressure issue.
              The manual does nothing to address the issue OP is having.
                Thanks,
                I’ve done this procedure before last year.
                The red TPMS light still came back.
                If not mistaken, it came back on while I was on the highway.
                No significant variance in pressure as far as I know.
                Nevertheless, I still did this procedure yesterday.
                It would not surprise me if it comes back on.
                  The 2003 manual states this information on pg. 84 and 85.
                  Even though I reset the TPMS yesterday, I reset it again using the procedure on pg. 85.
                  I may not be surprised if the red TPMS light comes back on after some driving.
                  I drive the most on the weekend at this point, so it may be a while.
                    And so I’m coming back from a work retreat.
                    (My car sat at the retreat for 2 days straight).
                    I’m leaving the retreat and drove the car for 5 minutes and the TPM light comes on!
                    In the beginning of August it was reset as per the manual and the light stayed off for 1.5 months now.
                    As the light came on today, I pull over and check the pressures.
                    There is no significant variance in tire pressures.
                    Thoughts?
                      Faulty speed sensors? Dont know just tossing it out there, but if i remember correctly, there are not tmps sensors in the wheels, but sensors that watch wheel speed,
                        Would addressing this be as simple as removing and cleaning the sensors, or would they require replacement? I’ve been getting the DSC and TPMS light pretty much every time I drive between Austin and Houston.
                        997.1 GT3 Carrara White/Black
                        C43 AMG Diamond Silver/Red​
                          Try pulling and cleaning them. The DSC/TPMS light suggest they are either bad, or dirty. If cleaning doesn't change it - replace them.
                            Originally posted by loudspeaker69 View Post
                            Thanks,
                            This procedure and a video on youtube helped me get rid of mine.
                              Our cars don't have tpms sensors do they?? I think it's calculated by tire rotations with the ABS system or something.
                              Check your tire pressures or maybe you have a slow leak?
