So I have just finished reassembling car after a major overhaul and rod bearing replacement. I have disconnected the fuel pump fuse (#54) and removed all the spark plugs and ignition coils so that I could crank the engine a couple times and get oil running through the system. Problem is it isn't cranking at all and the abs light just stays on while the key is out. I did replace the starter and tested my older one too but both don't spin. I have also checked all the grounds I know off. Anyone know what else it could be?
Car Won't Crank After Overhaul
Journal: https://nam3forum.com/forums/forum/m...grey-speed-runTags: None
Fixed it..... I'm just an idiot.2003.5 E46 M3 Silver Grey/Cinnamon
Originally posted by jet_dogg View PostDon't keep us guessing bro, we won't judge you2003.5 E46 M3 Silver Grey/Cinnamon
If there is any ground wires connected to the engine/tranny then these wires would burn up during cranking as the engine and tranny metal body had 12v during cranking in this case.2003.5 E46 M3 Silver Grey/Cinnamon
And the ground was in contact with the engine mount, it just wasn't on tight.
It doesn't matter if the ground cable was in contact with the engine, as the connection is bad causing the starter not cranking, then the full 12V will appear on the engine/tranny body during cranking attempt.
Are there any points worth checking out in case?
(Yes, if you had connected a test lamp from the engine to the battery negative cable or the body chassis then it would light up brightly during the starting attempt. )
For example, the ignition coils harness has a wire grounded to the head (13mm bolt I think) for the spark only happen in one polarity. And in this case adding 12v to the 15Kv makes no difference to the hardware. But, if you have some other after market products that have the wires grounded on the engine/tranny then they could be damaged by the 12v now appears on the ground wires. I don't think the DME is grounded on the engine, so it the car runs fine then nothing had burned. Beside the ignition coils ground wire, do anyone know of other wires connected to the engine/tranny body?
(Yes, if you had connected a test lamp from the engine to the battery negative cable or the body chassis then it would light up brightly during the starting attempt. )2003.5 E46 M3 Silver Grey/Cinnamon
