Originally posted by mrgizmo04
View Post
Subframe reinforcement, gear fluid changes, and bushing refresh
Ok, unfortunately the kit I have doesn't have anything with that small a diameter. Will have to rig something up.3.91 | CMP Subframe & RTAB Bushings | SMG (Relocated & Rebuilt) | ESS Gen 3 Supercharger | Redish | Beisan | GC Coilovers & ARCAs | Imola Interior | RE Rasp | RE Diablo | Storm Motorwerks Paddles | Will ZCPM3 Shift Knob | Apex ARC-8 19x9, 19x9.5 | Sony XAV-AX5000 | BAVSOUND | CSL & 255 SMG Upgrades | Tiag | Vert w/Hardtop
Did you ever figure out a good way to do this?Originally posted by oceansize View Post
I mangled one of my new upper control arm bushings pretty good trying to press them in.
Is there a preferred side to press them in from? The RTAB carrier seemed like one side was angled to guide the bushing, but the upper control arm looked to be flat on either side.
I think i bent the threaded rod on the bushing puller too, lol.
I did, to remove I used a combination of items from the BAV kit and a socket:Originally posted by mscott7426 View Post
1. Use BAV kit and 24mm socket to push out old bushing.
2. To push out attach the 24mm socket to the long side of the bushing
3. Attach the BAV bearing nut to the 24mm socket from step 2.
4. Use BAV tube on other end.
To push in I used:
5. To push new one in use 27mm socket and attach it to short end of bushing.
6. Attach BAV bearing nut to 27 mm socket.
7. Use BAV tube on the other end.
8. When close to the end of pressing the new one in the bearing nut end is "bearing nut"-> 24mm socket -> 27mm socket. BAV tube still on other end.3.91 | CMP Subframe & RTAB Bushings | SMG (Relocated & Rebuilt) | ESS Gen 3 Supercharger | Redish | Beisan | GC Coilovers & ARCAs | Imola Interior | RE Rasp | RE Diablo | Storm Motorwerks Paddles | Will ZCPM3 Shift Knob | Apex ARC-8 19x9, 19x9.5 | Sony XAV-AX5000 | BAVSOUND | CSL & 255 SMG Upgrades | Tiag | Vert w/Hardtop
Thanks!Originally posted by oceansize View Post
To push in I used:
I have a cheaper puller kit so was mixing and matching sockets to try to push the upper rear arm bushing in. Those were similar sizes to what I used, but I think I was pushing on the long end during install.
It seems like the bushings are particular to the direction you're trying to push them. I bent the threaded rod of my kit so I'll have to figure something else out, lol.
Hey thanks for that! It was a pretty good watch. Maybe have some descriptions of the work that happens in the episode so it shows up in search? I don't remember it popping up when looking for examples. It was cool to see you use the home wrencher methods in addition to the shop press.Originally posted by AussieE46M3 View Post
One question I'd have is do you not find the need to inspect / repair the top of front mounts? I checked mine and there is some minor cracking, but I don't know if it's necessary to do anything if doing bottom plates and a top bar.
Sadly, tinypic closed down and all the images were lost. I have the original saved post, but without any pictures sadly. The thread was originally created by bimmerfan08, who is a member here now. Bimmerfan, do you happen to have the original pictures? I can put the thread back together if you have them...
Thread=464146 User=bimmerfan08 Date=Sat, Dec-28-2013, 02:13:11 AM
The views on these videos are criminally low, compared to the quality.Originally posted by AussieE46M3 View Post'03.5 M3 SMG Coupe - Jet Black / Black
I find the top of the mounts don't usually have any cracks till the bottom has something going on. I usually do but honestly just got lazy. Filming makes any job x5 longer.Originally posted by mscott7426 View Post
Thanks mate.
It took a lot more time than I expected to film & edit etc. I haven't made content in a while as I just didn't have the time anymore. If I do again I'll probably have to sacrifice quality a little.
Thanks for sharing your knowledge, it's much appreciated.Originally posted by AussieE46M3 View Post
Thanks mate.
And yeah, I agree that the videos are very well done.
