Besides Schwaben or the brand that FCP Euro carries I was just curious if anyone is using anything different? Also if anyone is using one tool that does both extraction and filling or prefers two tools keeping them separate.
Fluid Extractor/Filler
I have this one
Buy Mityvac 7201 2.3 Gallon Fluid Evacuator Extractor and Dispensing Pump, Push Button, Manual Operation, Chemical-Resistant Polyethylene, Automatic Overflow Prevention, Quick-Drain Spout, Large Base: Fluid Evacuators - Amazon.com ✓ FREE DELIVERY possible on eligible purchases
It's pretty good but in hindsight, it would be nice to have one you can connect to an air pump instead of having to pump it manually, wait for a bit while it drains, pump it again, repeat... honestly that part is pretty annoying.
Schwaben/ECS have one that you can pump or connect to air supply, I think it's a bit more expensive and it also has nozzles/attachments to do other things like bleed brakes/etc.
I use just the pump Schwaben one, I pump it up 10 times, go grab some lunch and it sucks it all out. I used to stand there watching it and when I felt like it slowed down I would keep pumping like non stop. Discovered I just needed to be patient.
Youtube DIYs and more
I bought this one 5 or 6 years ago and it's been worth every dime for my "fleet". Trans service, P/S fluid exchanges, differential services where there's no drain plug, etc. It even came with adapters to use it as a vacuum source. I used it for that purpose in locating a leak in the hvac switching mechanism in my old F-250 that had decided to only blow air out of the defrost vents.
When it gets full, I just toss it in the truck and roll it into the nearest parts place to recycle the used oil. Easy peasy.
Harbor Freight is America's go-to store for low prices on power tools, generators, jacks, tool boxes and more. Shop our 1600+ locations. Harbor Freight is Built for Tool People
Sent from my SM-G988U using Tapatalk
