- Looks like the latest alignment on my daily driver has worn the rear tires only down to 3/32 in about 6K miles. Bought the tires from Costco which takes no responsibility, nor will the reputable alignment shop. I have two questions for some short term relief before buying tires and getting alignment. What's the optimal alignment spec for long term tires wear, and should I now rotate rears to the front on my square setup? I guess another question for the group is what tires do you recommend for DD in the desert with lots of heat and little rain? This car may get 8 - 10 K miles annually.
Guess I've also got a lot to learn about posting here! Here's the correct information. Michelin Pilot Sport A/S 3 installed 2-8-17 at 86986 miles, and aligned at that time. Current alignment was done 1-18-2019 at 93086 miles. As of today, the mileage is 98252, so the tires have about 12K in 3 years. Hope the photos are helpful. My concern is how much the tires have worn is 3 years and ~12K miles, if the alignment is basically solid.
Sorry about the errors and confusion. I'll never get how to post my photo's, but here's the numbers from the current alignment done January 2019: Looking only at the rears: LR camber -1.6 degrees, toe +.18 degrees. RR camber -2.0 degrees, toe +.15 degrees. Total toe +.33 degrees. As mentioned elsewhere, I drive this car like a sissy, but acknowledge driving habits can factor into this question. Bottom line, if the current specs look OK to the crowd, and I need new tires soon, I'm asking for recommendations for other than the Pilots I now have.
Thanks,
Steve
