I don't know if it matters, but in that instance I remove the RE lower washer. For the topside I use the RE washer, not the BMW washer.
Rear shock mount troubles
Email to [email protected]
- Likes 2
I'd say any are a good application for any street car and also an upgrade in terms of longer life.
Using urethane bushings that can be installed in either a stiff or semi-stiff position, this is the perfect rear shock mount for BMW E30, E36 and E46 cars. Made of 6061 aircraft aluminum, these mounts are a perfect fit for any shock. Two steel studs mounted to a steel bracket sandwich this mount to the body, and a
I am happy with my GC ones
Did you go ahead with these and how did you tighten the nuts? I went to install mine and there's no tool I could find that could get the 13mm nuts tightened with that washer present in the clearance the Z4M has in the mount area. I may just replace the nylock nut and do the mount nuts first.Originally posted by Halftim3 View PostIs this correct with the rogue rsms?
