I pulled the 20amp fuse for the fuel pump to perform a fuel filter change. However the car kept running.. It did run rough but did keep running for atleast 15 seconds befor i shut it off. What gives?
Fuel pump fuse. Car still starts
What a threadDD: /// 2011.5 Jerez/bamboo E90 M3 · DCT · Slicktop · Instagram
- Likes 2
Not trueOriginally posted by timmo View PostYeah, that's supposed to happen. And good thing you pulled the fuse or you'd have fuel spraying everywhere when you go to change the filter out
You're mostly correct. If you want to change your fuel filter (and car was run/primed recently), you don't need to pull fuse and run car till it quits. You can let pressure out at the Schrader valve on the FPR.
If the car's been sitting, there won't be any pressure.Last edited by Tbonem3; 08-18-2021, 02:13 PM.DD: /// 2011.5 Jerez/bamboo E90 M3 · DCT · Slicktop · Instagram
