SMG Software other than CSL
    Hello. Do any of you guys have experience with SMG software other than the CSL? The only one i know of is DINAN but not too much feedback on the forums. I purchased a second e46 smg and wanted to know if there is anything else available.
    Hi There - The one i use is tuning tech frank smith, i haven't had a need to try another one as it works very well!
    Here is the link: https://tuningtechfs.com/ttfs-smg-software/
      TTFS is just the stock CSL software AFAIK... except you have to pay for it.
      Dinan... does dinan have SMG software? If so, news to me. I thought they just corrected for different final drive ratios, but that is done on the ECU, not SMG tune, IIRC.
        I have a SMG DME with the TTFS tune on it. ( I swapped in a third pedal) I'm not sure about compatibility in another vehicle however. I'm willing to sell it if it works.
          UPDATING THE SMG ECU TO RUN CSL ‘255’ SOFTWARE
          In order to get the best from your CSL rev matching it’s advisable to upgrade the software on your SMG ECU/DME to CSL spec or’255′ software as it’s often referred. This is a fairly simple task but requires the following to be in place for a successful flash: – A battery tender or intelligent charger that is capable of working in ‘supply’ to provide 14V @ 10A. I recommend the CTEK MXS10. – A working installation of WinKFP (5.1.6 or newer) and the E46 Daten Files – A diagnostic cable that works with INPA/WinKFP, if you don’t have one, grab
          MSS52 / MSS54 BINARY MODIFICATION TOOL
          ( CSL SMG Shift / Rev matching + Inertia fix )
          Modification of your E46 M3 MSS54 and E39 M5 MSS52 ECU to enable one of more hidden features such as CSL rev matching, de-limit, SAP delete and shift lights
          Evolve Eventuri
            Dinan is just for the final drive as mentioned here. Guess csl is only option.
              Identical.
                Only difference is the software.
