Coding Fog Lamps and Bulb Recommendation
    DIY: Coding Fog Lamps and Bulb Recommendation
    I have a 2002 M3 coupe and I would like to code the fog lamps to default “on”. To be specific, I don’t want them on when the car is simply running, but I want them on whenever the light switch is turned to positions 1 or 2 and even when the high beams are on. I’ve tried unsuccessfully to do this using BMW Scanner 1.4. Does anyone know of a way to do this?
    Additionally, does anyone know what fog lamp bulbs can be used to match the color temperature of the Bi-Xenon lamps?
    Thanks…
    Just build better headlights man.
    2005 BMW ///M3
    Black6MT Daily
      Don't be that guy who drives around with his fog lights on all the time.
      What's with this matchy matchy thing everyone wants to do with their foglights I don't get it. I just got brighter bulbs and don't care what color they are as long as they're not fake-ids.
        I put in yellow PIAAs to actually use them in fog which I've done for maybe 5 minutes one time lol
          Well, I'm that guy. More light is always better than less and running fogs gives me a lower and wider side vision that the low beams can't. At least I don't leave my turn signal on...
            Don’t think you can do this with coding. Because of the relays, it’s a wiring thing not a coding thing iirc.
            Thought people use to run jumper wires and such (which I don’t suggest).
              Lotta fog where you drive jimbo?
                I live in one of the driest parts of the country. Humidity less than 5% is very common and fog happens here maybe once or twice a year. That said, I still drive with my fog lights.
