E46 M3 Navigation Delete
    Has anyone successfully replaced the navigation unit with regular business CD unit?
    I’m not interested in replacing the genuine stock navigation unit with aftermarket navigation unit.
    I haven’t, but I have one if you’re looking for one
      which navigation? BM54, BM24, Radio Navi?
        I intend to at some point when I can get my hands on the parts. From my understanding you need the full stereo harness which requires removal of the complete interior including carpet to install. Then the console bracket is different since hvac controls move and you gain a sunglass holder in its place.
          Should be pretty straightforward:
          Not many would want to do this but there is the odd situation where this information could be useful. In order to get a business CD into an e46 that original had a navigation package, you will have to pull cables from the trunk. 2 items you will need 1) A Business CD wiring harness from a...
          2003 Imola Red M3 w/ SMG
            Wouldn't this be the same procedure as installing an aftermarket unit with an extension harness? The business CD in my 323i was directly swappable with an aftermarket unit, but my m3 required an extension harness to be run from the boot down the side of the car and into the dash.
            I used the Eonon extension harness. There's a detailed installation video on youtube somewhere. I see no reason why this harness wouldn't also work with a business CD unit
              True, forgot about that method. I had decided that I’d rather do it with the OEM harness, since I’d prefer to replace and remove unneeded wiring rather than add more in.
                Bumping this thread back instead of starting another one. Has anyone converted Nav to non-nav using the oem harness? I would like to know if someone has done it and how to go about. I'm thinking of converting since I acquired a parts car and wouldn't mind the weight reduction and simplicity of the business radio setup. Paging Obioban, did you have a thread that showed how to go from Nav to business radio?
                  the E46F link above referenced someone that was able to do it but they cut/reconnected wires where it was convenient for them.
                  if you have a parts car then practice taking apart the interior with it, you pretty much have to strip the interior to sheet metal to get the whole harness out in one piece, the hardest part being where the wires cross from driver to passenger side near the shifter and under what i think is the heater core (which has to be removed unless you want to cut wires).
                  FWIW here are some weights that you guys should expect to lose if you're deleting the nav system, keep in mind you'll be adding some of that weight back with the addition of the business cd components
                  complete navigation harness: 11 pounds
                  rear trunk hardware (BM53, IBus, DVD GPS, amp, mounting cage): 15 pounds
