GearMotive Dogbox Going In
    GearMotive (https://GearMotive.com/en) is a precision machining and transmission manufacturing company headquartered in Sievi, Finland which specializes in race car gearbox and gear manufacturing. Race car gearboxes differ from normal manual transmission designs to handle greater power and torque. In addition, the gears of racing dogbox gearboxes can be shifted without a clutch. Clutch less shifting allows quicker, more robust gear shifting.
    GearMotive completes all racing gearbox manufacturing stages in-house including, product design, machining, heat treatment, assembly and services.
    GearMotive gearbox components are manufactured from premium high strength steel designed specifically for gear and gear shaft production. These high strength alloy steels provide superior stamina and hardness for long component life. Machining is completed with CNC-machines aided with 3D-models. GearMotive has tremendous experience in gearboxes, helping to design unique gearbox products and offer customers transmission related services.
    Company products are sold by GearMotive - Finland and GearMotive dealers throughout the world. Import and shipping to The United States is readily available from GearMotive headquarters in Sievi.
    The heart of GearMotive is accomplished by motorsport enthusiasts with a long history racing and race car building. Our racing background helps our staff understand customer needs and design new products for their racing purposes. Do not hesitate to e-mail us at [email protected] or call +358 40 8208969. We are open for any inquiries and gearbox related discussion.
    GearMotive has designed and manufactured successful dogbox transmissions models over the years. Recently the BMW ZF transmission has become a highly sought after dogbox in many racing classes. GearMotive has focused on ZF dogbox transmission production to serve customers around the world. Historically, Toyota transmissions have also been popular GearMotive products.
    GearMotive products are innovative by design. Many of the products are designed using our protected innovation, which allows building the gears stronger than our competitors in a certain limited housing arena. This innovation makes GearMotive racing transmissions stronger and more reliable.
    Product designing and manufacturing at GearMotive is an extensive process. This process begins with customer supplied specifics, including the car and engine model, current and potential future power and torque figures, as well as competition class regulations. When the necessary information is compiled, the gearbox design begins. Modeling gears and gear shafts in 2D and 3D simplifies the process for precise machining. The final crucial process prior to assembly is heat treatment, grinding and final finishing. All these properly completed manufacturing steps are critically important, resulting in a high quality product that is enjoyable to use.
    Information about GearMotive and their innovative products can be found at https://GearMotive.com/en/, Facebook: https://www.facebook.com/gearmotive or Instagram.
    MVP Track Time
    Feff, what’s the purpose of this post? This looks like copy pasta advertising to me.
    I assume you’re buying a gear box from them?
      Yes, it's hopefully going in today.
      MVP Track Time
        Whats the gearset they’re using?
          • 2 ratio sets available:
            • Long 1st gear, smaller drop between gears (Rally, Track):
              Ratios: 2.23, 1.71, 1.38, 1.16, 1.00
            • “Longish” 1st gear, bigger drop between gears (Drift, Rallycross, Drag, Street):
              Ratios: 2,73, 1,83, 1,42, 1,16, 1,00
          • Fits to housings: ZF S5D-260Z, S5D-310Z and S5D-320Z
          I'm doing the long set. Truly will be a 5-speed transmission now.
          Feff
          MVP Track Time
            The maiden voyage at Mid-Ohio last weekend with the GearMotive (https://gearmotive.com/en/product/bm...-speed-dogbox/) dogbox 5-speed was a complete success and an absolute brilliant design. The up & downshifts are lightning fast. I chose to use the clutch on all downshifts and about 1/3 of the upshifts, moving to clutchless upshifts as the weekend progressed with more mileage on the box. They click off like a fine bolt-action rifle. I screwed up and had no video card in the AIM Smarty Cam. I'll try to get some video from Road America in October.
            The breather vent line with a small air filter atop the vent line will be switched to a small vented catch can for easier and cleaner use. We didn't have the transmission fluid cooler hooked up because yours truly ordered the incorrect fittings for the ZF case drain/fill plugs but no issues. Said fittings and cooler will be completed this week with new Motul fluid.
            It was really nice not having any issues with high RPM downshifts, notably 4th to 3rd, from the stock ZF 5-speed. The sound, well it's a bit like a jet engine on track. Ear plugs are a must even inside my helmet with ear cups. 🏁
            Feff
            MVP Track Time
