Originally posted by LSBNick
View Post
VinceBar and Skinz - while I am there...
Camber adjustment is made between the round bar and the clevis (at the wheel end) using a stainless steel jack screw.Originally posted by K-Dawg View Post
In addition to the non-sealed joint (although it looks like they offer a boot), they are going to be more difficult to adjust than the bars with the adjustment on the outboard ends (Turner, Ground Control, etc).
The rod end is tucked into the subframe and not exposed to much road grime at all however, the boots are available to seal the bearing just like an OEM ball joint.
For those with non-raising bushings and are running quite low these arms offer positive adjustment beyond stock arms as well as negative adjustment well beyond stock to.
E brake cables - good thinking. Thanks.Originally posted by 90mtx View PostAnother maintenance item is the e brake cables. A bit easier with the subframe dropped. SuperPro makes an offset upper inner control arm bushing that you can correct/add/adjust about 1 deg of rear camber.
Jonathan
JesseOld, not obsolete.
Yep. There's bearing options however, they are about x10 the price and yield not hugely significant gains. It's a small bush so I'd be surprised if poly would make any difference but, does runthe risk of squeaking.Originally posted by D-O View PostIs an OEM rubber bushing the way to go on the inner end of the upper rear control arm?
Jesse
The upper control arm experiences about half the force the lower arm does so removing rubber in favour of bearing/ball joints on the lower arm will yield more gains in terms of geometry consistency.
What bearing options are there for that one, that's the only one I've not seen readily as most shops say don't bother.Originally posted by AussieE46M3 View Post
The upper control arm experiences about half the force the lower arm does so removing rubber in favour of bearing/ball joints on the lower arm will yield more gains in terms of geometry consistency.2003.5 MT JB/B - CSL SCHRICK SUPERSPRINT EISENMANN JRZ SWIFT MILLWAY APR ENDLESS BBS/SSR DREXLER KMP SACHS RECARO AR SLON MKRS GSP DMG KARBONIUS CP AUTOSOLUTIONS KOYO
My advice to everyone bar a 10/10th's track car is don't bother either. They all use spherical bearings that are fairly small to fit within a housing within the arm so they will be a service item.Originally posted by jet_dogg View PostI should have specified I don't want any turner, vac or bimmerworld stuff.
As I said above, go for a bearing mounted lower arm. You'll yield more than double the gains to an upper inner bearing as the lower arm experiences double the force and has a larger rubber bush that has more room for flex.
It's the only piece of rubber I suggest leaving in the rear suspension.
He's saying go with what you went with, wording is a bit confusing how you read it. I got spherical bearing lower arms I will be installing zero fucks about dirt since I won't be driving in the rain.Originally posted by WestBankM4 View PostToo late for my build, I went with Turner Rear Camber Arms, when I get under there I suppose I'll realize how much of a pain they are.2003.5 MT JB/B - CSL SCHRICK SUPERSPRINT EISENMANN JRZ SWIFT MILLWAY APR ENDLESS BBS/SSR DREXLER KMP SACHS RECARO AR SLON MKRS GSP DMG KARBONIUS CP AUTOSOLUTIONS KOYO
