Hoping maybe someone can give me a little help with diagnosing a problem on my m3.
Lately it's been driving "roughly", not necessarily a misfire but something's definitely up. Idle and light cruising aren't really affected but as soon as you lay into it any further it starts getting more rough and definitely seems down on power.
It's done similar things in the past and it's been coilpacks or TPS, but it just got a fresh set and the problem persists.
No CELs, EMLs, looking at all the sensors nothing looks out of place.
Oil and coolant look normal.
Air filter looks normal, it's probably 4 months old but definitely not plugged solid
Nothing sounds out place like it kicked a shim or timing chain noise, no strange leaks, smoke, the VANOS adaptations haven't moved.
I've tried logging the problem with testo and during the roughness nothing indicates a problem, no timing fluctuating, VANOS movement looks normal, throttle movements looks normal
Compression is 180 with no noteworthy detlta
Fuel pressure is 72psi, drops to 64 psi at idle
Note: With the test gauge installed after the regulator reading 72psi, if you close the valve (effectively isolating the front half) the injectors bleed down to 10psi within 20mins
Fuel filter is 2 months old
Smoke tested intake and exhaust for leaks, none currently
Spark plugs are 3 months old, NGK iridium, none of them show damage or strange color, they're all fairly consistent
Both the engine side TPS are new, also swapped out the gas pedal with a known good one and no changes
The only actual hard evidence I've been able to come across is the uneven running in INPA, nothing actually registers as a "misfire": screenshot attached
After that I tried swapped the 1/2 injectors and the cylinder 2 stayed as the worst, no real change.
I'm still leaning toward it's just time for injectors (to my knowledge there original with 200k) but I really hate just throwing money at it.
Any ideas?
Its a 2005 with 195k on it right now, it's running the CSL software with map sensor. I have a wideband and there's definitely rich spots, it feels similar to a rich misfire, but even it does it in the leaner spots too so that theory doesn't seem to pan out.
Sent from my SM-G965U using Tapatalk
Any ideas?
