Originally posted by TexaZ3
Pinion seal replacement + diff fluid question
https://www.amazon.com/Ford-XL-3-Fri...3912613&sr=8-4Originally posted by mtpktz View Post
Thanks for the heads up. Which FM do you use?
You need to mix 4.6% which makes it about 48 ml per liter. (1048*4.6% = 48)Last edited by TexaZ3; 10-10-2021, 04:41 PM.BMW / E46M Interior & Trim Restoration.
Thanks Alex!Originally posted by TexaZ3 View Post
Quick question - pinion nut size - 30 or 32mm? And do I need thin wall socket, or regular would fit?BMW / E46M Interior & Trim Restoration.
I put Amsoil 75w-140 in my diff. I don't have any whining noise but they also have a diff additive if you want to add that. Also the rear of my car is naked and I haven't heard any noise since switching.Originally posted by TexaZ3 View PostAbout to replace pinion seal on my diff, and having not done it before - do I need to drain the fluid in order to change it? I just did the fluid change like, 1000 miles ago, so would hate to discard perfectly good fluid.
If I do - is the Castrol 75W-140 SAF-XJ + FM still the way to go? Or is there something better out there (aside from super overpriced OE fluid)? Thanks!
Replacing the pinion seal in the car and you will lose essentially 0 fluid, basically what is just splashed into the recess of the seal.
Replacing the output shaft seals in the car and again the fluid loss will be very minimal.
Removing the diff and standing on the pinion you can change the diff cover without draining the fluid.'09 HP2S, '12 R12GSA, '00 Black 323iT, '02 Alpine 325iT (Track Wagon), '02 Alpine 330iT
Email to [email protected]
For the last option, can you get the paper gasket off without dropping any parts or debris in the fluid?Originally posted by George Hill View PostReplacing the pinion seal in the car and you will lose essentially 0 fluid, basically what is just splashed into the recess of the seal.
Yes, the paper gasket usually isn't stuck to the housing very securely. I use a razor blade and angle so it "pushes" the gasket towards the outside of the case. Also keep in mind getting debris in the housing is just as likely whether there is fluid in it or not.Originally posted by Slideways View Post
Generally though I do all the work on the diff, run it to temp/extended period without a load (like on the the lift) and then change the fluid.'09 HP2S, '12 R12GSA, '00 Black 323iT, '02 Alpine 325iT (Track Wagon), '02 Alpine 330iT
Thanks George.Originally posted by George Hill View PostReplacing the pinion seal in the car and you will lose essentially 0 fluid, basically what is just splashed into the recess of the seal.
Because Amazon has it for less than half the price of FCP, and I also have integrity not to return used fluids.Originally posted by Obioban View Post... why would you not have purchased the fluid from FCP previously?
Can't be. 36mm is way bigger than the lock plate for the nut. Its has to be 30 or 32mmOriginally posted by bigjae46 View Post
I'm think it's a 36mm and a regular impact socket works.
Yes, 32mmOriginally posted by bigjae46 View Post
It’s 32mm. You can use an impact socket.'09 HP2S, '12 R12GSA, '00 Black 323iT, '02 Alpine 325iT (Track Wagon), '02 Alpine 330iT
