Originally posted by digger
View Post
Crank / Balancer interface worn - anybody else seen this? Fix?
I do recall noticing the elongated shape of the hole on an undamaged balancer, but yeah this hole is definitely a little damaged. I'm very hesitant to attempt to recondition that surface on my own, on either part, unfortunately. The surface looks scored but it's smooth to the touch. I think the marks might actually be from heat. I do have a bunch of parts at a local machine shop for cleaning and measuring but they don't have a mill so they can't chuck it up and take a quarter thou off the top. I need to find a new shop.
It's crazy. They used to be $750~ish for quite a while. Right now the VAC damper is technically cheaper, which hurts my soul. Ross (in Australia) also makes a damper for about $675 shipped.Originally posted by Pklauser View Post
Dang, I had to check you on this and you're right. Wow.
https://www.ecstuning.com/b-genuine-...waAsXtEALw_wcB
would be a fretting type action (relative movement back and forth), there is probably a bit of stick slip going on due the angular torque pulses the damper is trying to absorb. Is the damper in good condition from a rubber perspective if its worn out the torque being transferred across the interface can get extremely high (i.e. enough to snap cranks due to fatigue)Originally posted by yellowltd View Post
I do recall noticing the elongated shape of the hole on an undamaged balancer, but yeah this hole is definitely a little damaged. I'm very hesitant to attempt to recondition that surface on my own, on either part, unfortunately. The surface looks scored but it's smooth to the touch. I think the marks might actually be from heat. I do have a bunch of parts at a local machine shop for cleaning and measuring but they don't have a mill so they can't chuck it up and take a quarter thou off the top. I need to find a new shop.Last edited by digger; 10-11-2021, 07:06 PM.
It was held by 4 long bolts, and so it could not spin around even without the dowel pin. The massive damper just oscillated back and forth with a loose dowel and causing the marred surfaces.Originally posted by jbfrancis3 View PostIt looks like it was run without the dowel pin for a period of time. I'm not 100% certain but I don't think you'd get those long scoring arcs with only a little bit of play in the dowel pin hole.
Nope, stock flywheel and clutch for the entire life of the car (125k mi).Originally posted by yellowltd View Post
Curious - do you have a single mass flywheel?
Me too! This fixes half of my problem. :-D2002 Topasblau M3 - Coupe - 6MT - Karbonius CSL Airbox - SSV1 - HJS - Mullet Tune - MK60 Swap - E86 Front Triangulation - ZCP Rack - Nogaros - AutoSolutions - 996 Brembos - Slon - CMP - VinceBar - Koni - Eibach - BlueBus - Journal
Duh, good pointâ€¦đŸ™„Originally posted by sapote View Post
It was held by 4 long bolts, and so it could not spin around even without the dowel pin. The massive damper just oscillated back and forth with a loose dowel and causing the marred surfaces.'05 M3 Convertible 6MT, CB/Cinnamon, CSL Airbox&Flap, PCSTuning, Beisan, Schrick 288/280, SS V1's & 2.5" System, RE Stg 1&SMF, KW V2, CB PS, Apex EC-7R
