What oil?
Is it coming from the front of the engine? Could be the vanos rattle. I'm running lucas 5w50 on my street (convertible daily). Warms up quicker, no issues with oil temp, no noises, and no oil consumption. Car is mostly a cruiser though.Originally posted by Advorsor View Post
Already replaced it
(I stand corrected by tbone)Last edited by enjoy_m3; 05-18-2022, 03:28 PM.
*PSA*
Talking about oil weights by using terms like 5w50 or 10w60 is almost useless. Just like tires - A 265 Michelin PS4S can be wider than some ling ling 275 tire.
Castrol TWS is called a 10w60, but it acts like a heavy duty 40 weight from my research. Then there's something like Liqui-moly 10w60 with a CST of 26+ at 100degress, which is about the highest I've ever seen, much higher than castrol or other 10w60s.
The "redline 5w50 instead of castrol 10w60" argument for S54/s65/s85 has gotten popular, but is redline lighter than castrol?
Well, 1st formula of redline had HTHSV rating of 5.9, newer formula is 5.0. Castrol is 5.3! Barely any difference. "ReDlInE is bEtTer in the CoLd!" Well, RL 5w50 has a cold pour of -45 and Castrol's is -39 so no.
Viscosity, Kinematic 100°C of Redline is 21, Castrol is 22.7, almost no difference.
You cannot conclude that redline is better for cold starts than Castrol just because Redline says 5w50 on the bottle and Castrol says 10w60.
Haven't even discussed additives. Perhaps Redline is low on additives because their product is meant for race cars. So even if redline and castrol were neck and neck in terms of viscosity and resulting oil pressure etc, Castrol could still be a better choice for most (Street cars) due to better/more additives.
Or maybe you have cats and don't want a race oil high in ZDDP? Castrol has other anti-wear properties that don't damage cats.DD: /// 2011.5 Jerez/bamboo E90 M3 · DCT · Slicktop · Instagram
In what sense?Originally posted by Tbonem3 View PostCastrol TWS is called a 10w60, but it acts like a heavy duty 40 weight from my research.
I know it used to shear down into the xW-40 range in service. Does it still? I remember doing some digging on this a few years ago and came to the conclusion that (then-)current formulations basically never sheared past the xW-50 range (min. 16.3 cSt @ 100º C).2008 E90 M3 6MT
2011 E90 328i 6MT
RWD, slicktop, no iDrive
What about 5W40 vs 10W60 then?Originally posted by Tbonem3 View Post*PSA*
Yes, it still shears from what I read, but not as much as it used to like 15 years ago is my impression. It also is fairly light to begin with, for a 60 weight.Originally posted by IamFODI View PostIn what sense?
What about what? I wouldn't run a 5w40.Originally posted by Advorsor View Post
What about 5W40 vs 10W60 then?DD: /// 2011.5 Jerez/bamboo E90 M3 · DCT · Slicktop · Instagram
I just find it interesting on Bimmerworld that they recommend it for Cold Temps in S54Originally posted by Tbonem3 View Post
I just use whatever they recommend at my local jiffy lube2002 TiAg M3 Coupe (SMG to 6spd), 2003 Jet Black M5
Hard to tell from the spec sheet, but I don't see anything to recommend it over any other decent xW-50 or xW-60 synthetic. Certainly wouldn't prefer it to BMW's recommended oil.Originally posted by BL92 View Post2008 E90 M3 6MT
2011 E90 328i 6MT
