Originally posted by IamFODI
What oil?
Not following either of bmw m or whoever came up with other guide blindly / as a blanket rule
How about option 3 that not following 1 or 2 blindlyOriginally posted by IamFODI View PostTwo possibilities here. Either
1. These guidelines show that BMW M's choice of viscosity grade was way off base, implying that M's engineers were unaware of this longstanding industry-standard knowledge; or
2. The M division knew something we don't.
Which seems more likely to you?
Two possibilities here. EitherOriginally posted by BL92 View PostMore salt on the wounds, Sorry guys lol
My ACL STD, measured at .002
Here are some recommended rod bearing oil clearances for various oil viscosities:
.0015 to .0018 for 5W-20 or 20W
.002 to .0024 for 5W-30 or 30W
.0025 to .0029 for 10W-40 or 40W
.0030 to .004 for 20W-50 or 50W
.0041 to .005 for 10W-60 or 60W
Video below
https://www.youtube.com/watch?v=aB-lf4kokSQ
Which seems more likely to you?Last edited by IamFODI; 04-13-2025, 10:13 AM.
Video below
Is this the one? Sorry, new to the platform and pictures between sites certainly aren't consistent. I think it's part number 15E99B?Originally posted by elbert View Postedit: looks like this deal is over
I just got Castrol Edge 10w60 for $8 /qt from Autozone
The page shows $12 /qt, but it will have the lower price once you add it to the cart.
They will also give you free no-rush shipping -- not sure if there is a minimum for this, as I bought 24 quarts 😬
They will also give you free no-rush shipping -- not sure if there is a minimum for this, as I bought 24 quarts 😬Last edited by elbert; 03-12-2025, 07:53 AM.
Most of it is; some of it isn't (sorry, Tbone).
Viscosity is the most important single aspect of a lubricant, so viscosity grade is very important. However, Tbone is right that you do NOT want to choose engine oil based on that alone because there are other differences that can matter.
The "TWS shears down to an xW-40" thing is many years old, based on rare occurrences, and even those cases it was often suspect (fuel dilution wasn't always ruled out). The factory oil's formulation has been updated several times since then and hasn't been shown to shear lower than xW-50 in years.
He's right that some of Red Line 5W-50's viscometrics are comparable to those of an old version of Castrol TWS. We don't know how that compares to modern formulations because not all the info is published.
He's right that one can't conclude cold start performance based on viscosity grade. It depends how cold you're talking about.
Red Line's products aren't lightly additized. Their race oils are light on detergent additives, but we're not talking about those here (hopefully). However, it's a VERY safe bet that Castrol/BMW's additive package is better suited for street use.
He's right that Castrol/BMW oil will be friendlier to cats than Red Line's (or basically anything from Penrite, from what I'm seeing), while retaining more than enough anti-wear properties that you don't have to worry about it.
The people who built this engine – the only ones who have a complete picture of what it needs – strongly advise sticking to the factory oil. This isn't like other engines, where they write a spec and say everything that meets the spec is fine; they're saying "you really should use this exact particular oil." And as BMW has gone back and back-specced more modern and thinner oils for so many of its older vehicles to simplify its supply chains, they haven't touched this one – except for that one time they released a confusingly worded bulletin and then immediately retracted it.
If you're going to insist on rolling the dice and deviating from that, at least stick to what your favorite lube manufacturer recommends. AFAICT, the only engine oil Penrite recommends for this engine is their 10 Tenths Premium 10W-60, and they actually go out of their way to say it's the only one you should choose.
Love your work, Brilliant write up, thank you
Most of it is, with some exceptions (sorry, Tbone).Originally posted by BL92 View PostGood Info
He's right that one can't conclude cold start performance based on viscosity grade alone. It depends how cold you're talking about and some other obscure viscometrics.
Red Line's products aren't lightly additized. Their race oils are light on detergent additives, but we're not talking about those here (hopefully). However, it's a VERY safe bet that Castrol/BMW's additive package is better suited for street use, as Tbone says.
Originally posted by Tbonem3 View Post*PSA*
Talking about oil weights by using terms like 5w50 or 10w60 is almost useless. Just like tires - A 265 Michelin PS4S can be wider than some ling ling 275 tire.
Castrol TWS is called a 10w60, but it acts like a heavy duty 40 weight from my research. Then there's something like Liqui-moly 10w60 with a CST of 26+ at 100degress, which is about the highest I've ever seen, much higher than castrol or other 10w60s.
The "redline 5w50 instead of castrol 10w60" argument for S54/s65/s85 has gotten popular, but is redline lighter than castrol?
Well, 1st formula of redline had HTHSV rating of 5.9, newer formula is 5.0. Castrol is 5.3! Barely any difference. "ReDlInE is bEtTer in the CoLd!" Well, RL 5w50 has a cold pour of -45 and Castrol's is -39 so no.
Viscosity, Kinematic 100°C of Redline is 21, Castrol is 22.7, almost no difference.
You cannot conclude that redline is better for cold starts than Castrol just because Redline says 5w50 on the bottle and Castrol says 10w60.
Haven't even discussed additives. Perhaps Redline is low on additives because their product is meant for race cars. So even if redline and castrol were neck and neck in terms of viscosity and resulting oil pressure etc, Castrol could still be a better choice for most (Street cars) due to better/more additives.
Or maybe you have cats and don't want a race oil high in ZDDP? Castrol has other anti-wear properties that don't damage cats.
Good Info, Can you please look into these oils for me ? Tbonem3
Thanks for answering again
Sorry man, I only picked up the car at 110k miles
When i pulled the thermostat, It was dated 2001, and the car ran at the 1st dot ( cold ), so i am not sure if was over heating prior
Here in Australia, all local Indy shops, Sticker the windscreen with a, ( Oil change due in 6 months or 3100 miles, Which ever comes first ). , As I do all the work myself, i seem to like those intervals with the money i save, Only the main dealers here are the 1s that insist on the extended intervals
What are your local indy guys like over there with interval changes in NA?Last edited by BL92; 03-01-2025, 09:21 PM.
Depends on the usage. If the engine is in perfect running order, with high quality fuel, doing few cold starts and a lot of easy highway miles, I can't see a reason you couldn't go that long. But there's really no way to tell without oil analysis (and even then it's sketchy).Originally posted by WoGGo View Post
I'm no expert, but isn't 13,840 KM (8,600 miles, and more on some of them) quite an excessive oil change interval?
Personally, I'd never run it that long regardless of usage.Last edited by IamFODI; 02-28-2025, 08:49 PM.
