Uh ok, I think perhaps my ABS unit kicked the can or something because as I turned on my car and looked at the dash, I see 4 yellow lights all simultaneously turn on. DSC, e-brake, tire pressure and trans gear are all yellow. I disconnected the battery but the lights are still there. The car seems to run and drive fine, did a bit of research that it could possibly be bad wheel speed sensors or ABS unit.
3 Warning lights all related to wheels
Originally posted by Calb View PostSame thing happened to mine at 57000 kilometers. Faulty DSC. Car drove fine btw.
Originally posted by Jimbo's M View PostIf you rely on the DSC to "nanny" you, I suggest you go out and see if indeed it is active. Otherwise...
I have been having this. The 4 lights are all yellow on my cluster. Maybe not your issue, but something to think about. I have read an alignment will fix this. In my case, I have replaced a few suspension bits. Haven't had any luck getting someone to align it, so can't tell you if it is going to work. I am debating doing the string theory alignment if it doesn't get done in the following week. I cleaned all my wheel sensors. Did not do a thing.
