Originally posted by Mattn1192
Battery Recommendations
Originally posted by Mattn1192 View PostMini battery is about $200,@ nearest auto parts store
If you don't want AGM, you can get a normal wet cell H5 for $109 at Sam's (Duracell) or Home Depot (Exide), or $120 at Wal-Mart.
The original H6 size is about the same price as the H5.
Optima is a waste of money and time.Last edited by K-Dawg; 11-05-2021, 01:42 PM.2003 Imola Red M3 w/ SMG
Originally posted by K-Dawg View Post
...for AGM. You can also get a Duracell (East Penn) AGM H5 at Sam's for $170.
Diehard Gold H5 in south Florida is $1802003 Imola Red M3 w/ SMG
Originally posted by simon_c View PostAnybody running the Interstate H5 battery from Costco? Almost $50 less than the Diehard equivalent. Only drawback is that interstate is a little heavier at 39lbs vs 32lbs2003 Imola Red M3 w/ SMG
I've been running the Shorai 36ah battery for over a year now. Lifepo4, 4.5lbs. If you don't have a huge sound system that you listen to for hours without car on, it works great. Can sit for a month without charger and starts right up. Can be found $250-300. Doesn't have antigravity circuitry to shut off to preserve charge, but I hook it up to a charger when I know car will sit.
Youtube DIYs and more
I had a Champion H7 battery in for only 2 years, then ran into the issue (possible?) with power drain with the BlueBus module (there was a firmware fix), but with capacity and power being higher on my priority than weight savings, I picked up a Interstate H7 AGM from Costco - no issues for the past couple of months.
Hey, thanks for sharing your battery experience! It's always helpful to hear about others' choices. I had a power drain scare too, and it turned out to be a firmware issue. It's great to hear the Interstate H7 AGM from Costco has been working well for you. Have you looked into a battery group size chart? I found it super useful when picking out a replacement. Last edited by RainaCochran; 11-24-2023, 03:34 AM.
