Hi all, I just picked up an E46M 6spd. The car makes a rattling noise (nothing like a heat shield) when accelerating fast (doesn't do it if you accelerate slow). Any idea what it could be? Car has 167k miles on it.
Rattling noise coming from rear right while accelerating fast
i went underneath it I couldn’t see anything wrong with it. I do plan to drop the subframe and reinforce it.Originally posted by Ipeciulis View PostCould be anything from a broken subframe, to worn diff bushings, to a driveshaft center bearing. Someone has to get under the car.
however, I was going through the service records and found out when a shop installed diff bushings, they mentioned the diff has excessive backlash. Does that mean my diff is bad?
