I went to start my car today. The fuel pump primes but nothing. I used my other key and the valet key still nothing. I tested the battery and that was good. No codes no nothing to read. Any suggestions
Starting issue
It cranks but it won’t start? Or it doesn’t crank?06 ZCP SMG | HTE CSL MAP QuaranTune | SL CSL Airbox | Eventuri Scoop | DMG Strut Bar | RE El Diablo | CPI Euro200R | AP Headers | Porsche BBK | ST XTA | TMS 3-Pulleys/F-Sway/Mono FCAB | AKG Trans/diff/Subframe/RTAB | SPL RCA | SGT SCZA Trunk | ACL | Beisan | Redish | AFD E85 |
Budget CSL MAP Conversion
Sounds like a starter06 ZCP SMG | HTE CSL MAP QuaranTune | SL CSL Airbox | Eventuri Scoop | DMG Strut Bar | RE El Diablo | CPI Euro200R | AP Headers | Porsche BBK | ST XTA | TMS 3-Pulleys/F-Sway/Mono FCAB | AKG Trans/diff/Subframe/RTAB | SPL RCA | SGT SCZA Trunk | ACL | Beisan | Redish | AFD E85 |
Try putting the car in gear and rocking it back and forth, then try starting it. You might have to do this multiple times. If it starts after doing this then the issue is your starter. Flat spots form on the starter contacts and the rocking can help knock the starter into a place that's not flat spotted. I had to do this a couple times while waiting on my new starter.
If your car is a manual you could also try bump starting it.2002 Topasblau M3 - Coupe - 6MT - Karbonius CSL Airbox - MSS54HP Conversion - SSV1 - HJS - Mullet Tune - MK60 Swap - ZCP Rack - Nogaros - AutoSolutions - 996 Brembos - Slon - CMP - VinceBar - Koni - Eibach - BlueBus - Journal
