Racing Diffs Common Mistake Video
    This popped into my youtube feed. I found the threadlocker demonstration video informative. Had no idea there was a difference in applying loctite in through holes vs blind holes.
    Excellent find.
      Agreed. That's some great info. Thanks for posting.
      I also recently learned about the threadlock thing. Seems so obvious now that I think about it, but I never gave it a second thought before. Makes me wonder how many times I've messed that up in the past.
        There is a common theme with me an mechanic work which is that within 24 hours of completion I will see exactly how I screwed it up online.
          The thread lock part is questionable. The recommended method will result in wasted compound, varying effectiveness based on the tap drill depth, and a weird hydrolocking effect depending on thread tolerance.
          I would be more inclined to put it on the male and female threads in both thru and blind holes.
            Yeah filling the hole is a really bad idea. Just put it on the internal threads thread it in and out to distribute rather than make a swimming pool
