17" Track Rims - Apex Rims
    This was talked about a while back in the old Forum, but curious if people are still running this setup?
    I had 18s APEX that I sold because the cost to paint them would just be the same as new wheels so I decided to just sell them and start fresh.
    Now with a clean slate I want to buy properly. Since it will be for track use and not every weekend. expected 4-6 a year. I want to get the 17x10 ET25 in Black or 17X9.5 ET35 Under the Porsche kit. Tires are about $40 cheaper a corner for Nittos.
    Anyone have any real world experience? I know Obioban has had this setup before.
    Outside of the obvious: Lighter weight, cheaper tires, more rim protection. What can be the possible negatives?
    It was discussed here: https://nam3forum.com/forums/forum/s...96-brake-setup
    17x10 ET25 will fit apparently, 17x9.5 ET35 will only fit in EC-7 form.
      Less options for tires.
      That's the only negative.
      I run a set of 17x10 Forgelines and they clear my Brembo GTR front kit.
      Going back to my square rear CSL setup makes the car feel soooo slow haha
      2005 BMW ///M3
        Significantly less tire options, and ET25 up front... which is 10mm more aggressive than I want.
        The ET25 is ultimately what pushed me off of them. If there was an et35 setup that could clear a BBK, I'd still be on 17s.
          apparantly i can't search for sh*t then. Good to know, I will stick to 17x10 then.
          I think I will stick to NT-01s. Even after years still seems to be the best "track" tire. I want something light and 17s seems to hit the ticket. But dont want to spend the extra coin for the RS series to save more weight (unless its huge I will need to check)
          how come? Too aggreessive for street or in general? When I had 18x10 ET25 it was normal back then. I felt it was awesome. Im sure on 17s it would feel even better (lighter)
            et25 requires a bunch of static camber to function correctly. My car has retained enough suspension geometry that I don't need ton of static camber, so it pushes me well into sub optimal territory.
            (as determined by pyrometer)
              I run 17x9.5 +35 Arc 8s as a street wheel. I do need to use 12mm spacers to clear my 996 brakes but I don’t mind that too much. If I had known I would have gone with the 10” wheels to begin with. I love the extra sidewall for a street wheel, especially driving over poor condition roads. One of my favorite roads goes up the side of a volcano and the pavement is heavily cracked from the earth shifting underneath it.
              At some point I will probably go to an 18” street setup for better tire selection and use the 17s as track wheels.
                WAT.
                2005 BMW ///M3
                  WAT.
                  Mt St Helens. It’s closed in the winter so this route isn’t exactly correct, I mostly drive NF-25 which is the other twisty road going south from Randle, and then there’s a turnoff to Windy Ridge.
                    Gotcha, I was imagining an E46 M3 driving around Mordor lol.
                    I'm like 17's ain't gonna help haha
                    2005 BMW ///M3
                      Was this for spoke clearance?
                      Or just close to ET35.
                      Trying to move away from ET25s up front, but struggling in 17" to find anything that'll work. Bought a set of Apex ARC8 17x9.5 ET35s, but they don't clear the brakes.
                      Ian was your issue spoke or drum clearance?
                        Yes.
                          Yes.
                          front and back? 10 wasn't enough?
                          I had to run a 5mm spacer with 18x9.5 et 35 apex rims to clear spokes
                            There is something about 10mm spacers that doesn’t work properly, I ended up shearing more than one lug stud when I was using them. I only needed the spacer to clear the brakes in the front, but I matched it in the rear for looks as well as starting to run into clearance issues with the shock.
                              I believe 10s don't have hubcentric ring, and 12s do right?
                              I need my mtb to sell so i can justify the wheels. luckily its not in stock anyway so I can wait. Not sure about tires though
