The carbon slicktop thread
  • DJAM3
    The topside where the clearcoat is sprayed. After some heat cycling, the clearcoat slowly goes from perfectly smooth to being textured in the pattern of the CF weave. From what I understand , they remove the part from mold, scuff it up, spray automotive clearcoat and then sand and polish.
    My Karb roof has developed a orange peel texture. Is the fix just getting it re-cleared or will I have to apply a layer of epoxy?
  • bavarian3
    It can be a future project/mold if enough interested.
    I also think a CF exposed headliner could be cool with matte finish
    How many would be needed? Count me in.
  • CrookedCommie
    Any suggestions on how to rust proof some of these drilled holes?
    Is it as simple as a rust-oleum rust spray? ...or is there something thicker I can apply with a brush?
    Click image for larger version Name:	pic3.jpg Views:	0 Size:	44.2 KB ID:	317841 Click image for larger version Name:	pic2.jpg Views:	0 Size:	63.0 KB ID:	317842 Click image for larger version Name:	pic4.jpg Views:	0 Size:	77.9 KB ID:	317843 Click image for larger version Name:	pic1.jpg Views:	0 Size:	94.6 KB ID:	317844
    Wurth brushable seam sealer might be a good option, will also kind of match the color
  • Gt4
    YES. Gt4 please make some headliner blanks. Let customers upholster.
  • Epsilon
  • P Swayz
    This!!!!
    Only thing holding me back at this point...
  • Epsilon
    I may have missed it, but what do you plan to do about sourcing a slicktop headliner?
    I got lucky and was able to find a UK Ebay seller to ship the headliner to the US. I paid him a bit more on top of the listing price for his trouble and about $400 USD to ship to the US.
  • bavarian3
    This reminds me. I have a stripped down slicktop headliner in the garage that I should 3D scan for documentation purposes. Maybe someone like Gt4 can even use the scan to start making replica headliners?
  • heinzboehmer
  • bavarian3
    FYI - I paid $2500 for the labor alone and he sourced the OEM glass from a local dealer which I also paid for. Carbon roof, new OEM seals, and roof bow were supplied by me.
    I should have asked for the street car installation package instead of track car. lol
  • bigjae46
    I recently had a carbon slicktop conversion at a popular Southern California shop. My car was transported over to the shop and I was unable to inspect the work in between or after until it was transported back. I also had my own carbon roof which was transported to the shop. I have my own headliner which I did not ask the shop to install. The shop owner was easy to reach and friendly at the time and I'll just leave it at that.
    For anyone else looking into doing this, let this be a list of items to look out for.
    Here are my observations after getting the car back:
    *OEM Windshield is misaligned. This is visually obvious with how much gap there is on one side compared to the other (see photo).
    *I see scratched paint in the side gutter of the windshield seal like a metal screw driver was used to pry it.
    *New windshield seal has a 1-2mm rip
    *Parts of the front and rear windshield seal edge were folded in. As simple as it sounds, I used a trim tool to lay the edges flat against the glass
    *Glued on roof rail on one side is misaligned. Where the rear window seal and roof rail meet, the window seal protrudes up compared to the other side.
    *Inside, there are drilled holes that are not sealed or rust protected
    *I see a pried sheet metal roof panel flare out (see photo)
    *I see multiple drilled through holes. Instead of drilling just enough to separate the roof panel, welds should not be drilled through.
    *Although water tight from my own testing, there are internal areas where I am expecting to see glue but don't see any used.
    *The trunk antennae hole was not covered and my trunk was soaked. This also caused condensation in my left taillight. I think this was during the water test for leaks. Owner told me to cover it up with a plug, but in my head I'm thinking why he didn't just tape over it in the interim if he knew about it.
    *My C-pillar covers were yanked out instead of properly removed
    *My rear tint was scratched up along the edges
    *My roof rails were painted black, but I see dirt particles under the paint. I feel like using my nail to scratch off the dirt, but it's painted over.
    *Will have more photos when I get a chance.
    In short, I love the way the carbon roof looks but wish the workmanship was better.
    In terms of drive, I can feel the car having less lean around street corners, but my main goal was mainly aesthetics.
    Click image for larger version Name:	left_right.jpg Views:	0 Size:	204.7 KB ID:	317524
    Damn, that sucks. Disappointing it is a well known shop.
    Looks like the underside is a unidirectional cloth? I can see the threads woven into the carbon. I wonder if they just layup up a cosmetic layer and then built it up with a unidrectional cloth which would be cheaper and faster. But I'd be a little disappointed with a $2000 roof. You want to layup the roof with a +/- 45 degree cloth to better align with the loads.
  • Epsilon
    Sorry to hear this, and it's a bummer for all of us. I assumed they were the go-to given their apparent experience with the project.
  • bavarian3
    You guys are right. I got work done at 2M.
    I was lured with their euro headliner saying that they may have one available and if my car was in their shop, I could get it first before others waiting for it. Once my car was transported there, the story changed to how their mold is almost complete and it just kept dragging out since. After 2 months of waiting with no headliner, I just wanted my car back and then I posted my observations in my initial post. David was very pleasant to work with throughout the process and there was no way I thought anything could go wrong with all the carbon conversions they may have performed. I did have to press him a little to start working on my car and either he was very passive because he was very agreeable or I was just a fool. Likely, the latter.
    They have been stringing along production of the headliner for over a year now, even having sold one on marketplace, then going back to "still working on it". Ref: https://nam3forum.com/forums/forum/m...730#post263730
    Looks like the best way to do this job is at home, like most jobs with these cars.
  • Epsilon
    spill the beans so others don’t don’t get shitty craftsmanship. We have a whole thread dedicated to speaking about bad service that’s justified. Sucks they didn’t do a good job but don’t protect them….they didn’t protect your car.
    That sucks, but the only way this post would actually be helpful is if you name the shop so others can avoid it.
  • 0-60motorsports
    I guess get whatever you want, karb is one of the best in the market and everything is manufactured in house.
