Originally posted by SignatureJames
The carbon slicktop thread
Yes because they are not manufactured any more. If someone has one sitting in the "back", thats the only way you'll get one. Im still surprised they discontinued the CF roof. ridiculously stupid.
CSL roof is definitely a hardcore grail body conversion. OEM ones are getting tougher to locate…
They are no ETA at the momentOriginally posted by Obioban View Post
Aren't they NLA?
Yes you can install themOriginally posted by discoelk View PostFactory (steel) slicktop here. Can I install CSL roof rails with no drama? I don't plan on putting a roof rack on this car and I like the look of the rails without the doors.
I believe the threaded inserts are welded to the roof structure so I'm not sure if they would interfere. I don't want to cut anything if I can help it.
I grabbed an extra set off a non-m slicktop and for the life of me can't find them. I'll PM you if I can dig them up.Originally posted by Avedis View PostAnyone happen to have an extra slick top coat hanger bracket? Apparently they are NLA. I was able to order the right bracket and the roof bow, but no luck on the left bracket.
51168223047
I would bet Mpartsworldwide has someOriginally posted by Avedis View PostAnyone happen to have an extra slick top coat hanger bracket? Apparently they are NLA. I was able to order the right bracket and the roof bow, but no luck on the left bracket.
51168223047
Thank you! Expect a text from me later this week. Would love to to clarify some things before superglueing this thing on. I also just added you on IG. I've been posting some clips to stories of all the "fun".Originally posted by SQ13 View PostGodspeed brother. Shoot me a text if you have any questions. (832) 3I2-474O
Check out my DIY thread. I shined a light around the perimeter from the outside and made sure no light was coming thru on the inside. No leaks and no noises. You just have to take your time and do it right the first time.
bhenderson def check out SQ's DIY. Not sure I would've tackled this myself without it. The idea is that the roof perimeter is sealed to water by panel bond. Then vibrations are handled just like the factory does by using windshield adhesive or similar between the roof bows and cf panel.
Check out my DIY thread. I shined a light around the perimeter from the outside and made sure no light was coming thru on the inside. No leaks and no noises. You just have to take your time and do it right the first time.Originally posted by bhenderson View PostI am curious with these carbon roof installs, do you have to deal with leaks or noises? How do you ensure it's sealed properly?
Indeed. Good things. Very good things.Originally posted by bavarian3 View Post
Things are happening.
I keep thinking, I’ll do this someday when all the other problems with my car are fixed, but then I remember what car I’m talking about.
- Likes 3
