The carbon slicktop thread
  • Slideways
    The alignment of the roof being off, the roof rails not fitting properly and issues with the damaged spot welds reminded me of this video, which was posted in the carbon roof DIY thread:
    He highlights all those issues and more with the roof he is removing.
  • Slideways
    What do you mean by textured? The underside of the roof?
    Composite parts will have a thin layer of the matrix or resin above the fabric reinforcement if the mold surface is polished smooth. For example the roofs I make, you see a clear layer of epoxy which if wet sanded and polished will look glossy. The problem is I think most clear coats are polyurethane which does not chemically bond to epoxy. So you have to get a mechanical bond but roughing up the surface. There are clear gel coats which are epoxy compatible but even those will fail after enough heat and UV exposure.
    The problem is epoxy does not thermally expand, polyurethane does. So if you clear coat the roof and it gets hot enough, then you'll start to see the clear coat separate.
    Duratec sunshield is the most widely used product for UV protection. It is a sprayable clear gel coat. A lot of shops will spray sunshield in the mold and then layup the part.
    The topside where the clearcoat is sprayed. After some heat cycling, the clearcoat slowly goes from perfectly smooth to being textured in the pattern of the CF weave. From what I understand , they remove the part from mold, scuff it up, spray automotive clearcoat and then sand and polish.
  • Epsilon
    Originally posted by Arlen4369 View Post
    I think OEM windshield is NLA
    Salt on wound
  • Arlen4369
    DM'ed earlier.
    I reached out to the shop and long story short, he is not accepting responsibility.
    I only asked for the cost of the windshield to be realigned and likely a new one if cracked during removal. He offered $140 for what he paid to his windshield installer of 10 years and claims that it's 3rd party and he is not responsible. OEM Windshield is like $500+.
    Anyway, moving on. Send a DM to barvarian3 for questions. lol
  • Epsilon
    This is scaring me off from doing the job. It seems hard to get a perfect fit and there's no going back once you rip that og roof off. There have been others with water sealing issues as well.
    Epsilon please provide or DM the shop name.
    DM'ed earlier.
  • bigjae46
    Challenge definitely did not make the OEM roofs. BMW did those in-house until the tooling/mold wore out, at least that was the reasoning I remember.
    I'm not sure if it was only Challenge or Karbonius who made the F80 style roof for the E46, but I have seen one example where the clearcoat has textured from the CF. I have also seen an Evolve roof do the same.
    Whatever resin or coating the BMW factory uses does not texture like this. Maybe bigjae46 can explain.
  • SQ13
    Ignore the condition of my front windscreen moulding—my bad for not using a new seal when the glass was reinstalled. I watched my glass guy install the front and rear glass. All he did was push the glass up towards the roof until it wouldn’t slide up anymore. If that’s how your glass was installed, I think your roof was installed slightly crooked.
  • Epsilon
    Hey Fellas
    So i have another E46 M3 to modify. My previous was FBO and I got the Challenge CSL roof (2014), as I heard they made the oem roofs at the time.
    Do they still make the roofs? Are there better quality ones out now?
    Kareem
    "RKP Composites has acquired every BMW aero component mold from Challenge USA."
  • Slideways
    I'm not sure if it was only Challenge or Karbonius who made the F80 style roof for the E46, but I have seen one example where the clearcoat had textured from the CF. I have also seen an Evolve roof that had the same issue.
  • Epsilon
    Hey guys, the only thing that can "easily" be fixed is the windshield and I want to see if I can get that repositioned locally. I'm going to let thing setting first before giving out the shop. You can drop me a shop name I will let you know if I recommend them or not or don't know.
    On a side note, does this rear window seal look right? Not the crease, but how the edges fold up and the gap?
  • 0-60motorsports
    Hey Fellas
    Kareem
    Karbonious bro! I highly doubt challenge made the OEM roofs. No way.
  • x Spades x
    Hey Fellas
    Kareem
  • bavarian3
  • Nate047
    That sucks, but the only way this post would actually be helpful is if you name the shop so others can avoid it.
  • Epsilon
    Damn dude, so sorry to hear about the issues. This is exactly what I was worried about and why I decided to just DIY it. Hopefully you can get everything sorted out.
    For anyone thinking about DIYing, I made a DIY thread that you can check out. I’m also happy to do installs for locals if my schedule allows.
    Had I known you offer installs, I'd probably consider shipping my car out to you if the numbers add up. This project was already expensive just parts alone.
    I purchased all the tools to DIY too but just couldn't find the time to do it with family and work. After seeing so many E46s and other M3s come out of this shop on IG, I thought my car would be under quality care. The owner knows his E46s in and outs, but I don't know if he works on the cars himself. The folks who's had their conversions done probably never looked inside since their headliner's installed by the shop already.
    Not sure how I can work things out with the shop yet as I'm still undecided.
    Even my wife noticed this:
    Click image for larger version  Name:	MisalignedWindshield.jpg Views:	0 Size:	100.4 KB ID:	317626
