Originally posted by SQ13
The carbon slicktop thread
Did you center punch the spot welds? I bet that helps a lot with the walking.
You need to use some cutting fluid and also use relatively light force initially so that the guide bit can have a divot to follow. One the divot is formed, you can press down harder so that the spot weld cutter can make contact with the metal.Originally posted by SQ13 View PostYeah I think it’s just for alignment purposes. With the Karb roof, I’m temporarily snapping in the original roof rails, as well as measuring the front and rear edges all the way across, to help make sure it stays square.
I did use the Blair bit with a Milwaukee drill and constantly struggled with 1) the bit walking off and 2) having to apply a ton of downward pressure to get it to cut. Maybe I wasn’t doing it right. Would like to hear how you did three sides in 30 mins lol.
Agreed. Belt sander with 3M 80 grit belt was very efficient for removing the protruding spot welds and cleaning up the surfaces, and I would highly recommend it. It would likely work well to grind down the spot welds if using the Blair spot weld drill bit isn’t desired…just need to be careful and not go too deep.
I did use the Blair bit with a Milwaukee drill and constantly struggled with 1) the bit walking off and 2) having to apply a ton of downward pressure to get it to cut. Maybe I wasn’t doing it right. Would like to hear how you did three sides in 30 mins lol.Originally posted by Sid_E46 View Post
I was using a Neiko spot weld cutter and went through 3 bits on one side on top of taking forever. Switched to the Blair spot weld cutter and went through the other 3 sides in like 30 minutes.
Also used a cheap Harbor Freight bandfile to clean up the surfaces. Made the process super easy.
https://www.harborfreight.com/53-amp...der-58155.html
I was using a Neiko spot weld cutter and went through 3 bits on one side on top of taking forever. Switched to the Blair spot weld cutter and went through the other 3 sides in like 30 minutes.Originally posted by SQ13 View PostThis shit sucks ass lol
I would assume the nubs were an alignment thing for the roof panels.
I did notice this as well and just ended up grinding down the nubs.Originally posted by SQ13 View PostFYI for those who are installing a Karb roof… The corners on Karb roof are not cut at an angle like the OE and other aftermarket roofs. The angled cut allows the roof to clear a welded nub on each corner, and I believe it avoids contact with a layer of sheet metal for the A and C pillars (will confirm this tomorrow since apparently none of the pics I took contain fully exposed corners). If the second point is true, that means the roof will sit more flush with the body/bows. Additionally, there is 6-7 mm of overhang on the front edge of the roof.
It’s kinda surprising that after looking thru this thread, other online posts, and in the vids I’ve seen for the Karb roof install, only one person mentioned the overhang and no one talked about the nubs. I think they ended up grinding down the nubs and leaving the overhang as is (except for the one forum member here), which I’m sure is fine. I’ve been tempted to do this as well to avoid the extra work of cutting carbon fiber lol.
Anyways, the point of this post is to let future Karb roof installers know that Karb recommends cutting both the angles on the corners and the overhang. And to clamp the front and rear edges every 10-15 cm, especially if the roof is slightly raised at one corner. BMW’s official install instructions calls for five clamps each on front and rear edge….as long as you’re not using two clamps like I’ve seen some people do, you’ll probably be fine. Just follow either Karb’s or BMW’s instructions. And wear proper PPE if you end up cutting the roof—you do not want to inhale the CF dust and have fibrosed lungs.
- Likes 4
Would love to know the story here and how much it cost you lol.Originally posted by Arlen4369 View PostWhen there’s a will there’s a way! Huge day for myself and my OEM LSB CSL tribute build. Thank you to the special person who made this all happen , you know who you are.
Gotta leave the headliner off now tho
