Anyone know if an exhaust piston from another vanos can be used to replace a damaged one (accident with pick) in a different vanos, or are they bed in/unique to the vanos?
Using parts from another vanos
Originally posted by Arinb12 View PostAnyone know if an exhaust piston from another vanos can be used to replace a damaged one (accident with pick) in a different vanos, or are they bed in/unique to the vanos?
Pics of the scratch by the pick?
I think the piston has fair amount of clearance -- they need seals to seal -- so they should be interchangeable. The same cannot be said on the pump disk tight clearance.
When you say the same can't be said for the pump disc, do you mean the disc itself or the surrounding spring, caps and ring?
why would the disc not be interchangeable considering the springs and caps push against the outer ring and so have some ability to compress or withdraw further?
Originally posted by Arinb12 View PostWhen you say the same can't be said for the pump disc, do you mean the disc itself or the surrounding spring, caps and ring?
