Since I switched from 400lb to 450lb springs on the front end and my front end has been noticeably bouncier. Can't be 100% sure whether it was before or after the spring change. I assumed my dampers needed a rebuild, they are 29k miles old. They probably do but I thought maybe I needed to turn up the compression and rebound.
I adjusted compression (bottom) from about 4 of 11 clicks to 6 of 11 clicks. No issues.
I went to adjust the rebound on top and the adjuster was on full soft. Don't remember it being that low. I recall running 1/3 from full soft both rebound and compression.
Has anyone had an issue with the top adjuster moving on its own?
