Looked around but really didn’t find anything definitive..
If a solenoid has gone bad/going bad, is EML/Limp mode a possible symptom? I know EML usually refers to throttle/TBs/I etc but wondering if can be caused in this situation too.
Some observations on my car.
- My idle, while mostly stable typically sits 800-900RPM but every minute or so, the idle will quickly climb or drop +/-200 RPM in either direction then return to the 800-900 area
- Limp with EML (sometimes) comes on going from cruise speeds on highway to WOT. I have to pull over and turn engine off/then back on after 2-5 seconds
- Limp without EML (sometimes) comes on after decelerating from highway speeds towards slowing down when going off exit ramps. I do the same procedure above
- Finally, on COLD mornings, EML sometimes on right away when I turn the engine on. There will be weak acceleration if I apply gas. Solution here is typically wait to the engine warms up for a few minutes then turn car off/back on. Full power-band is usually restored.
Just trying to rule Solenoid out.
