Originally posted by MrClutch55
Hotchkis Sport Swaybar Set Reviews?
It looks like most people are only running a stiffer front say bar, with OEM rear. I'm trying to use the FCM guide. What Front Roll Couple (FRC)% are you guys shooting for? The stock M3 FRC% is 66.5% while the CSL is 70.9% so CSL would have more tendency to understeer over base m3? It seems like I would want my car to be setup for more oversteer like characteristics rather than understeer. What FRC should I shoot for?
Originally posted by M3mike View PostIt looks like most people are only running a stiffer front say bar, with OEM rear. I'm trying to use the FCM guide. What Front Roll Couple (FRC)% are you guys shooting for? The stock M3 FRC% is 66.5% while the CSL is 70.9% so CSL would have more tendency to understeer over base m3? It seems like I would want my car to be setup for more oversteer like characteristics rather than understeer. What FRC should I shoot for?
Originally posted by T.J. View PostIt should be noted that the outer diameter of bars is only part of the equation of torsional spring rate. The tube wall thickness and material shear modulus play a role. These probably don’t vary tremendously from one manufacturer to the next but from Turners description of their bars: “These bars are crafted from a special spring steel that is both stronger and more resilient than competitive sway bars”
Turner bars are H&Rs.DD: /// 2011.5 Jerez/bamboo E90 M3 · DCT · Slicktop · Instagram
Didn't see anyone mention having broken any of the mounting brackets? I really like the H-Sport bars, but my friend has broken a bracket two times in some 6 years.6MT SLICKTOP - OE CSL Wheels - OE CSL Brakes - CSL Rack - CSL Trunk - CSL Diffuser - AA Tune - AA Pulleys- AS 40% SSK - 4.10 Motorsport Diff - Bilstein PSS9s - H&R Swaybars - CSL Lip - Gruppe M CF Intake - Supersprint - M Track Mode
Maybe running on stiffest with stock or relatively low spring rates.DD: /// 2011.5 Jerez/bamboo E90 M3 · DCT · Slicktop · Instagram
Originally posted by LVMESM46 View PostIm seeing Turner bars are ST Suspension bars. Could it be possible more than two are the same?
If this thread is being revived I just want to chime in that I ended up buying the Hotchkis front bar and run it on softest setting with a stock rear. The front end feel in transitions is greatly improved, and I'm about to install some Dinan springs to pair with my Koni yellows.2002 M3 Coupe | 1988 320i Touring
- Likes 3
