CSL air shut off valve
    When installing a CSL style Airbox I understand that the original air shut off valve can be reused rather than buying the csl air shut off valve?
    Is this correct? If so what needs to be modified?
    Why is the CSL one any different?
    Don't think the air valve is different, but the hose connects to the airbox in a different spot, and the hose is hard plastic and won't bend. So you need the CSL version or cut off the hard plastic line from the connector and swap the line for a silicone hose.
    Regards
      https://nam3forum.com/forums/forum/m...-breather-tube
      EDIT: Whoops wrong tube...what COVID-19 said unless you want to buy the CSL version.
        Just cut a section and add rubber hose.
        Budget CSL MAP Conversion
          Buildjournal aka Andrew did a write up on this on his website.
          It's rather easy.
          2005 BMW ///M3
          Black6MT Daily
            Why would you spend thousands on an airbox conversion and cheap out on a hundred bucks?
            Baffling.
