I need to figure out the value of my M3. Considering selling it.
2003 Imola/Black manual w/104,xxx miles.
Has quite a bit of preventive maintenance within the last 8k miles or so:
-New OEM Clutch Kit
-New Slave Cylinder
-New Hydraulic Line
-New Master Cylinder
-New Front LCAs and Bushings
-New Tie Rods
-New Front Sway Bar End Links
-New Valve Cover Gasket
-Reman Alternator
-New Serpentine Belt
-New Final Stage Resistor
-New Oil Level Sensor
-New E-Brake Handle
-Rod Bearings under warranty at 12k miles.
No noise from VANOS.
Aftermarket upgrades:
-Delrin Clutch Pedal Bushings
-Headers (likely off brand)
-Active Autowerks Section 1&2
Issues:
-Rear quarter panel has a scrape that will need professional repair.
-Needs either an o2 sensor or a coil. It gets a misfire code but does not appear to actually misfire.
-Needs bushings on the differential mounts. (I have not looked at the subframe areas in a while, but I can check/take photos).
-Stereo was previously an aftermarket setup. Replaced with a stock head unit but I suspect the speakers are not connected (no music).
-Sunroof interior panel clip needs to be replaced.
Will be addressing the misfire code, changing fluids, and having the audio repaired in the next month or two.
-New OEM Clutch Kit
-New Slave Cylinder
-New Hydraulic Line
-New Tie Rods
-Reman Alternator
-New E-Brake Handle
Issues:
