Just finished my engine build and made a respectable 370whp on a mustang dyno which is excellent but my flow matched stock injectors are maxed out and I need to upgrade to something with more flow. I was recommended at least 440cc like the bosch green giant as well as 550cc but am looking to see if there are any options that are a direct fit to replace the stock ones in terms of fit and connector type as I don't want to have to run adapters or reengineer the electrical rail harness. They need to be the same spray pattern as stock as well so the car will idle properly.
Does anyone have any recommendations for an NA build that sees street usage? I don't want any bs with fuel trims when not at WOT. I know injector dynamics is a go to for S54 but they are way too big for an NA car.
