PNP Upgraded Injectors for NA Build?
  • heinzboehmer
    Originally posted by thegenius46m View Post
    I went with Bosch 52lb 550cc EV14 injectors. Honestly if you have cams and any headwork it is highly recommended to upgrade to injectors. Stock is a waste because my head is flowing so much air he had to dial back the tune considerably because stock injectors maxed out so quickly.
    Are those plug and play (besides tuning)? Will be building an engine soonish and injector upgrade might be worth doing.
  • 9kracing
    My car is actually in the shop right now, and they are having a hell of a time installing my ID1050x injectors. They are telling me the universal adapters don't fit correctly and the injectors are leaking air. I'd always had good results with ID, has anyone heard of the ID injectors not fitting our cars?
  • thegenius46m
    Originally posted by fullyflaredd View Post
    Curious, did you end up purchasing a set? If so which ones did you go with?
    Have pretty much the same.mods as you and will be getting my car tuned by Hassan in a month or so, and have been told by a few people now that I should upgrade injectors while I'm at it.
  • fullyflaredd
  • thegenius46m
    Also I just chatted with some people on this bosch 750cc and for an NA car on stock dme, there is concern these might be challenging to scale down at lower load situations. Can anyone confirm they have run these on an NA car that sees street usage?
  • zzyzx85
    Any issues given they are now made in China vs Germany? Wonder if the FiveO is just a safer bet to not deal with extra issues?
    In terms of stock injectors, I installed a set of Chinese made Bosch injectors last year and they've been fine over the 15k miles I've driven.
  • thegenius46m
  • Martyn
    Yup, the 996T injectors fit without modification. I can't comment on the FiveO ones though, but the length matches the 996T injector I have in my hand.
    Personally I wouldn't bother with the flow matched units unless you've got an EGT probe installed per cylinder to actually allow you to dial individual cylinders in properly as the airflow to each cylinder isnt equal anyway.
  • thegenius46m
    Those porsche 996T injectors are 'plug and play' in terms of physical install, I ran them for a while on my charged M3. The spray pattern is different (conical vs V) though but I had no issue dialling the the idle.
    Perfect! Even Bosch couldn't give me the specs to confirm I had the right part number. Lol.
    So I just found these a minute ago that claim they are plug and play for S54. Honestly I think its the same Bosch Porsche injector that has been flow matched. Can you confirm that these are both the so called "Porsche" injector that fits stock rail for S54? Non-flow matched is half the price, but if I were to get that done second hand it comes out to close to the same amount so probably will just go with the ones below.
  • Martyn
  • thegenius46m
    Originally posted by JustAnother46M3 View Post
    Tip is the same, If you look BMW puts the O-Ring on the Plastic Housing.
    That Audi Injector just has a small ring/cap on the tip to hold the O-Ring down on the nozzle probably for a slightly smaller O-Ring. Slide the Cap and O-Ring off and it'll look just like the standard EV6 used in the S54.
    S54 use a 0280156052, you can also get 0280156012 (440cc) Porsche Inj
    Same Family of injector.
    Do you know if the Porsche injector (Bosch #62625) is the same length and plug and play with our car? I can't find dimensions anywhere.
  • dl.m3
    Spray pattern must be the same as OEM I am being told or you will require quite a bit of tuning to get the car to idle properly. Imagine most of you would not want to deal with that.
    Is it not as simple as re-scaling the global injector factor?
    Very interested in this since I was planning to refresh my injectors soon anyway. the OE bosch ones seem to be out of stock everywhere and cleaning my original ones cost almost the same as new ones.
    Maybe ill find some used old Audi TT injectors to test fit
    Sent from my HD1905 using Tapatalk
  • stash1
    Paging Paulclaude...
  • JustAnother46M3
    I can't imagine Bosch making different spray patterns for the same injectors in a family.
    I'm 99.99% sure this is as close to the OEM S54 Injector as you will get.
    Also the spray pattern doesnt need to be the exact same. The main concern is just a quality injector with a good spray pattern offering good atomization and mixture.
  • thegenius46m
