PNP Upgraded Injectors for NA Build?
  • JustAnother46M3
    Tip is the same, If you look BMW puts the O-Ring on the Plastic Housing.
    That Audi Injector just has a small ring/cap on the tip to hold the O-Ring down on the nozzle probably for a slightly smaller O-Ring. Slide the Cap and O-Ring off and it'll look just like the standard EV6 used in the S54.
    S54 use a 0280156052, you can also get 0280156012 (440cc) Porsche Inj
    Same Family of injector.
  • dl.m3
    Originally posted by JustAnother46M3 View Post
    - New Guy Here*
    Been looking into this as well as I'm wanting to run Flex Fuel in the future at some point.
    I came across the 225 8N Audi TT (0280156063), uses EV6 style injectors just like us. I have no dimensions to say how close they resemble the OE injector fitment but visually they look very close. Rated at 386cc it should bring you down atleast 17-20% IDC comparing to the stock rated 268cc.
    Good lead but it looks like the nozzle is slightly different which may lead to a different spray pattern or location. That would be my concern
    Sent from my HD1905 using Tapatalk
  • JustAnother46M3
    - New Guy Here*
  • Chas3n
    Corey, what are the ones I have on mine? Welcome to have them.
  • thegenius46m
    Nice number, looks like you owe lang an apology LOL!!
    Just kidding 🤠
    Lol I don't think it would have made these numbers if I didn't have my local machinist catch the leaking valves before I had him swap them. But I will give Lang's machinist credit for the pocket porting.
  • jet_dogg
    Just kidding 🤠
  • thegenius46m
    started a topic PNP Upgraded Injectors for NA Build?
    Just finished my engine build and made a respectable 370whp on a mustang dyno which is excellent but my flow matched stock injectors are maxed out and I need to upgrade to something with more flow. I was recommended at least 440cc like the bosch green giant as well as 550cc but am looking to see if there are any options that are a direct fit to replace the stock ones in terms of fit and connector type as I don't want to have to run adapters or reengineer the electrical rail harness. They need to be the same spray pattern as stock as well so the car will idle properly.
    Does anyone have any recommendations for an NA build that sees street usage? I don't want any bs with fuel trims when not at WOT. I know injector dynamics is a go to for S54 but they are way too big for an NA car.
