Originally posted by stash1
It's probably good to not stroke this engine for daily driving. These pistons move extremely fast as is. I'm about to start another Power and Performance class. I think I'll be mapping tunes(I won't be an expert by any means) so I should learn alot more about this in depth over the next few weeks. Hopefully the teacher doesn't suck. I do wish the school didn't pull the Flowmaster out of the curriculum though.
This aggressive build is going to be sick. You should document this on Youtube.
, it's entirely possible to run big boy cams in an S54...and retain VANOS. The Schrick cams that you're both referencing are actually 304/296 duration specs, and it's actually more the lift than duration that gets you into trouble.
higher compression has never been easier👍 you'll need a pump upgrade and injectors and a tune (not a fan of piggybacks).
