Updated information is that no matter what cams you get, doesn’t matter the profile, new followers are required. I bought new schrick cams (280/72) this past year in November installed this spring on my car, even replaced two exhaust followers on cylinder 6. I got stepped cams now.
Schrick cams are now “cast” per new products description. I’m confident this was a new development in the c19 era. Even vac didn’t have the required anecdote for this profile cams. They also come polished, cam lobes are no longer coated black. Unfortunately I’m out a lot of money cause warranties are not honoured unless you get their proprietary followers.
Need advice on followers
If anyone has updated info on any cam followers it would be a great help, looks like some are backordered and some places are sold out.
Does anyone have a source on the 320is followers (11337549034) that is in stock? Schmiedmann still shows it as OOS but allowing backorders. The price has increased on them but still less than Schrick followers.
i wonder why we dont see any aftermarket followers yet, so many companies offer a support for our cars
even the schrick ore catcams versions are just the 320si ones
They were made in the Landshut Formula One factory and specifically designed for high rpms. I think they'll do just fine.
Those are the ones. People had good things to say about them in the 288/280 vs 270/272 thread (but they were a lot less conclusive on that part).Originally posted by pynacl View Post
I'm SUPER curious about these E90 320is followers, they're nearly half the cost of S54 ones. Please keep us posted how this works out! Out of curiosity where did you source them from (assuming they are 11337549034)?
I ordered them from emiauto.eu, cost was about $55 per follower after exchange rate and shipping. Will update when I get them in.
I'm SUPER curious about these E90 320is followers, they're nearly half the cost of S54 ones. Please keep us posted how this works out! Out of curiosity where did you source them from (assuming they are 11337549034)?Originally posted by DoubleSidedTape View PostI have a flat follower. Should have been able to figure this out sooner but it’s an issue I hadn’t encountered before. One valve was way out of spec (more than 0.2mm), and I have a tapping sound coming from that part of the head. Tore things down today and sure enough that one is done.
I ordered a set of the e90 320is followers and the 288/280 Schrick cams. It looks totally doable to remove/install followers with the engine in the car; I pulled the front end off this afternoon and it took me about an hour, I’ll pull the airbox and start disassembly of the top end probably sometime next week.
While this is an upgrade I was planning to do eventually, I am a bit disappointed that this money is going into the engine rather than a set of seats.
Yikes! I wonder what causes this wear all of a sudden. Usually a hardening issue shows up early in an engine's life so ...Originally posted by DoubleSidedTape View PostI have a flat follower. Should have been able to figure this out sooner but it’s an issue I hadn’t encountered before. One valve was way out of spec (more than 0.2mm), and I have a tapping sound coming from that part of the head. Tore things down today and sure enough that one is done.
Looks similar to the wear I noticed on my last valve adjustment at 135k: https://nam3forum.com/forums/forum/m...-camshaft-wear. For the $3k+ for new cams/followers I'd just send it as-is and save up for a head rebuild. Personally I added a dimple magnetic drain plug to mitigate any possible accelerated wear and put the valve cover back on and plan to check the condition at the end of each season.
- Likes 5
I know, just did this. Not impossible nor difficult though, just labour intensive. I'd rather do it now though when the head is already off..Originally posted by Tbonem3 View PostIt's quite a lot of work to remove them...
Regards
thanks for the input guys
about why i dont know exactly, ive got a oil analisys done and it said that from the last oil change, it ha some wather/coolant in the system and its more likly like 10w50 now
thats why i have took the head off and and replacicng the head gasket
i think i will put this set back on, becosce the coating will cost 1/4 of the new followers, and make few more frequent oil changes with the analysis to check how everything is going on
and with time will gather some fund for schrick cams and followers
I wonder why you're getting scoring. My engine at 100k shows no such wear.
Either way they don't look bad, certainly nothing catastrophic. I bet you could do another 100k on those parts.
