Yes, I looked on the internet already. From my previous research it seemed pretty safe to run 15MM front and 12MM rear spacers lowered on ZCP wheels with no fender rolling and no rubbing. The front is not an issue. My rear ride height is at about 13 1/8" from middle of center cap to bottom of fender, so nothing crazy. It doesn't rub over regular bumps only larger ones and heavy compression. But when it does rub it seems to get it pretty good. If anything the driver side sits slightly higher with no driver and seems to be rubbing worse than the passenger side. Alignment is from when I had my previous set of wheels and I imagine more aggressive on camber than most people have so I'm not sure why I'm having this issue. Is there something stupid I'm missing here? Or will I have to suck it up and just run a less aggressive spacer? Tire is a 265/30 Michelin Pilot Sport 4S and suspension is Ground Control street coilovers.
Untitled by jake ellegard, on Flickr
