Here is the youtube link, anyone here has this experence before. Mainly every time I hit the engagement point and release gas and gas again. When I raise up the car noise from near by the tranny, but inside the car noise from rear driver side. Sometimes bumpy road had the noise too, inspected bushing from driveshft and fiexdisc all look good. PLEASE HELP!!!!
Noise when clutch engage. Please help!!
Here is the youtube link, anyone here has this experence before. Mainly every time I hit the engagement point and release gas and gas again. When I raise up the car noise from near by the tranny, but inside the car noise from rear driver side. Sometimes bumpy road had the noise too, inspected bushing from driveshft and fiexdisc all look good. PLEASE HELP!!!!Tags: None
Is your front diff bolt tight? Mine sounded similar when it failed.2002 Topasblau M3 - Coupe - 6MT - Karbonius CSL Airbox - MSS54HP Conversion - SSV1 - HJS - Mullet Tune - MK60 Swap - ZCP Rack - Nogaros - AutoSolutions - 996 Brembos - Slon - CMP - VinceBar - Koni - Eibach - BlueBus - Journal
Did you double check the diff mounting bolts are not loose?
On the video i have my friend do the clutch engage and disengage. The noise is happen when the clutch is engage and gas pedal increase. I will check the diff mounting bolts later and see. I have someone check out the vehicle, he said might the dual mess flywheel defected, is that possible too?
Originally posted by alex8831 View PostOn the video i have my friend do the clutch engage and disengage. The noise is happen when the clutch is engage and gas pedal increase. I will check the diff mounting bolts later and see. I have someone check out the vehicle, he said might the dual mess flywheel defected, is that possible too?
Normally a lightly more backlash DMF can cause a noise but not like this, unless this one has 90 deg or more backlash which is very bad.
If he disengaged the clutch then why the shafts were all spinning non stop or low down?
