Hi all, recently I refreshed my s54. I ended up rebuilding the vanos (whole beisans kit), rod bearings, complete reseal; headgasket, timing cover gaskets, and more. The engine had to come out for all the work. Yesterday, I tried to fire the car up, it would crank but not start. The spark plugs were getting flooded with fuel. So I checked for timing a few times (dead on) and I have good compression. I took the MAP sensor out and sprayed some starter fluid with new plugs. Same thing car would crank but not start. I have confirmed I have fuel pressure as well. I plugged in my scanner and I have no codes. Any idea?
S54 Crank no Start but I have (fuel, spark, and air)
Originally posted by Ajcanadian View PostThe spark plugs were getting flooded with fuel. ... I plugged in my scanner and I have no codes. Any idea?
No code because if DME detects the bad condition, it still needs to have certain crank revolution with the bad condition before register the codes.
Nothing you have said indicates you have spark. In fact it seems that's the most likely problem given you're not getting any kind of firing of fuel or starter fluid or otherwise.
What are you reading codes with? I'd guess a critical sensor is missing. Pretty sure missing the ground on the side of the head won't result in no spark however it's been known to damage DMEs.
Originally posted by Shonky View PostNothing you have said indicates you have spark. In fact it seems that's the most likely problem given you're not getting any kind of firing of fuel or starter
fluid or otherwise.
Scanned with snap on scanner, car specific and OBDII generic route.
Timing has been checked again, all cylinders at 130-140 psi compression
Wild ass guess. You say timing is good - I assume you're referring to cam to crank timing? Is it possible to be out by 360 and still have the cam timing check out as right? ie cams out of phase by 180 would mean pins still fit in the timing tool wouldn't they?
Compression sounds a bit low to me. I would be expecting more like 170.
Originally posted by Shonky View PostWild ass guess. You say timing is good - I assume you're referring to cam to crank timing? Is it possible to be out by 360 and still have the cam timing check out as right? ie cams out of phase by 180 would mean pins still fit in the timing tool wouldn't they?
it’s also a cold compression test. I’m sure it’ll go up after the engine is warmed up, right?
Originally posted by S54B32 View PostMake sure you have Vanos pressure if you have removed and cleaned the internals of the pressure regualtor. I had the same behavior with far to less vanos pressure.
Originally posted by Shonky View PostCan't see how VANOS would prevent it firing. At worst cam timing is slightly off but it should still start or fire off. At the very start, there will be little to no pressure in VANOS. It takes 5+ seconds once actually running for VANOS to get up to any sort of pressure.
Don’t ask me why, but maybe 1 or 2 bar is not enough to move the splines.…under construction.
But it was in my case. Even multiple 10 sec cranks won’t fire it up. Adjusted the screw and after one more 3-4sec crank it fired up.
Don’t ask me why, but maybe 1 or 2 bar is not enough to move the splines.2005 ///M3 SMG Coupe Silbergrau Metallic/CSL bucket seats
At startup the splines don't need to be moved. The cams are in the default (retarded) position at start up.
edit: i need to look into the tune, but if i remember correct the intake is full retard and exhaust full advanced during idle. so i assume they move while startup.Last edited by S54B32; 05-03-2022, 10:38 AM.…under construction.
