Hey gang.
Just finished installing CMP solid subframe bushings, CMP solid differential bushings, replaced all the suspension bushings with new ball joints and sphericals. (autocross street mod car)
When I got the diff off the car, I noticed had a decent amount of output flange play on the drivers side. The car is a 2005 with the original differential. You could probably wobble the flange 3/8". Passenger side was solid, no movement. Also to note, no diff sounds out of the ordinary before this evolution. The car was previously on powerflex poly subframe bushings, and AKG 95A poly diff bushings. The diff was quite oily, and it was too difficult to know where the leaks were coming from.
Quite evident the diff was in less than good health at 140K miles, I decided to replace the diff seals, refresh the fluid and monitor, hoping to get one more season out of the diff before a rebuild.
I got the car on the road and immediately noticed a notable "whirrr" sound, or a sound like "zzzzzz". The sound is speed dependent. I have the sound when I clutch in. No noticeable leaks after only a few miles drive.
Repacked the drive shaft CV, and torqued everything by the Bentley.
Have a listen in the video and let me know what you think.
Thanks.
Thanks.
