Alternator Pulley Bolt Tool Combo
    I wasn’t happy with the whole “just hit the pulley bolt with an impact” method of securing the pulley to alternator. I also didn’t want to buy the dedicated tool for this task. So I went in search of what tools to get.
    Basically you need a 24mm socket with flats on it (hard to find these days) and a long T45 bit (but not too long). I found the following tools work:
    Amazon.com: uxcell 1/2-Inch Drive T45 Torx Bit Socket S2 Steel 100mm Length : Tools & Home Improvement
    and
    Not all alternators have the T45 drive on the shaft so check yours before buying.
    I forgot to take photos before putting everything back together but basically you use the T45 bit on a ratchet while using a 1” wrench on the socket flats. Hold one while turning the other and voila!
    Torque for pulley bolt is 33 lb-ft
    But… after all that hitting the pulley bolt with the impact was, in fact, tight enough.
    BMW makes a 24mm socket for alternator pulley removal/installation. It's fairly cheap too. Part number 83300491167
    SF Bay Area Vanos, Rod Bearings, Inspection II, etc. Services : Member Feedback
    E46 M3 Track Videos : https://www.youtube.com/c/DanAvon
      My understanding is that tool would only replace the 24mm socket. Still need a slightly longer torx/allen bit. Also that part current ship date is a month away. I was able to order the milwaukee socket to my local hardware store the next day.
        I bought the same two parts as you and have performed 3 pulley installations - well worth it and very durable.
        David
          Notice the price went up on the BMW tool at FCP for this. Use to be cheaper. https://www.fcpeuro.com/products/bmw...10-83300491167
          They do however offer this other internal socket for under $10.
          But as mentioned you’ll still need the long torx bit if one does not own a larger set of torx tools.
